Results 1 to 2 of 2
Thread: Weber carbs, Italian made or ???
    Many early 911s were equipped with Italian made Weber 40s.
    There were also replacement Webers made somewhere else ( Spain ? ) I'm not referring to PMOs, Zeniths or Solexes.
    Are there differences between the OE Italian jobs and the later replacement Weber units ? eg. interchangability, quality, specs, features ? Just asking.
    Jan 2003
    UK
    These later Webers were made in the USA by Carter Carburettors & were of inconsistent quality which gave rise to multiple problems & this eventually led to Richard Parr producing his own uprated/improved evolution - the PMO.
    Here's a quote from Matt Blast of Eurometrix:
    "Richard actually offered his expertise in trying to help the Carter Corp. work out the bugs (and there are many) but his advice was ignored. The Italian Webers are a work of art really.....nicely done castings and precision machine work.
    The Carter Webers are hit or miss. Some of them worked OK but some did not. If you ever take them apart make sure you carefully check for shim rings in the emulsion tube wells (under the emulsion tubes) because sometimes the wells were machined too deep and shims were used to raise the emulsion tubes to the proper level. Also the shims are of varying thickness because the wells are not all the same depth. If you lose the shims (a lot of them are lost by now) they don't work so well.
    They also had shaft misallignment issues and other problems. "
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. FS: 40 WEBER IDTP13 IDTP13C Carburetors Italian Made
    By 914-6gt in forum For Sale: 911 Parts
    Last Post: 01-18-2014, 12:22 PM
  2. Weber 40 IDA Carbs - Italian, 1968
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 08-25-2012, 06:17 PM
  3. FS 46 mm webers- italian made
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 07-31-2009, 03:56 PM
  4. Weber 40 IDA ; made in Italy or not...
    By RS-GT in forum Technical Info
    Last Post: 12-16-2008, 06:18 AM
  5. Italian Weber 46s
    By BURN-BROS in forum For Sale: 911 Parts
    Last Post: 07-22-2008, 04:51 PM
