Results 1 to 7 of 7
Thread: Shock absorbers for a 912
    Senior Member Milou's Avatar
    Mar 2006
    Geneva
    I need to change the shock absorbers of my 912. What would you recommend I use? I suspect I won't need the Bilstein used on a 911 as the car is lighter and I'm lookimg for a fairly comfortable drive.
    Thanks for the help,
    Milou / Registry #884
    www.ecurielyford.com
    Senior Member Aldo's Avatar
    Dec 2007
    Austin Texas
    Milou- I've been very happy with the Bilsteins (not Sports)I installed to
    replace the original Boges. It's about an equal split between
    Bilstein and Koni on most 912s now. KYBs are cheap but too
    harsh according to some that have tried them. Not many use
    Boge/Sachs- I don't know why.
    If you haven't already, visit the largest 912 community:
    www.912bbs.org
    Alan Domme
    Austin, TX
    '68 912 coupe
    '16 VW Golf R
    Early 911S Registry #1361
    912 Registry
    Mar 2006
    Geneva
    Aldo,
    Thank you so much, seems right to me. I'll order them and visit the site!
    Member 912's Avatar
    Jun 2008
    Salinas,Ca.
    Hi Milou
    I've been very pleased with Koni. Mine are set on a soft setting but would recommend a bit stiffer setting for sportier driving.
    Ken
    Aug 2006
    Sonoma, CA
    Remember the 912 is about 300# lighter than the 911 and 99% of that difference is in the rear. I don't believe that the rear of a 912 responds to gas filled shocks.
    johnt
    Mar 2006
    Geneva
    Trying to log myself onto the 912 site. In the meantime, I have another questions possibly valid for 911 from 1966 as well: Where would the fog light switch go?
    Would the switch be located next to the steering wheel vertically below the gauges, or horizontally in the middle of the dash like later models?
    Thomas, the fog lamp switch is in the horizontal row next to the hazard and webasto.
  1. 73 S shock question
    By Haasman in forum Technical Info
    Last Post: 12-19-2012, 05:40 PM
  2. Shock Color
    By MrJTP2001 in forum General Info
    Last Post: 10-21-2012, 09:45 AM
  3. Koni Shock ID
    By Haig Haleblian in forum Technical Info
    Last Post: 02-10-2010, 12:47 PM
  4. Nut on top of shock (front)
    Last Post: 05-18-2006, 01:39 PM
  5. Engine lid shock
    Last Post: 11-01-2005, 07:17 PM
