Thread: Brake attaching bolts
    I am looking for a set of two bolts that attach the front brake caliper to the rotor assembly. There are two on each side, thus four bolts total. Does anyone know a supplier for these four bolts?
    Thank you.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Get the OE ones from porsche, they are a 10.9 property class, black oxide steel. Not expensive and you should use new ones for such a critical fastener.
  1. FS: early front seat tracks and attaching parts
    Last Post: 02-19-2014, 12:54 PM
  2. Replies: 9
    Last Post: 12-16-2013, 03:47 PM
  3. FS-EARLY seat belt original attaching brackets
    Last Post: 09-01-2011, 11:22 PM
  4. Brake caliper bolts SWB
    By tlmsf in forum Technical Info
    Last Post: 03-28-2010, 02:05 PM
  5. attaching Window to base of mechanism
    By Marktodo in forum Technical Info
    Last Post: 04-25-2008, 08:52 PM
