Results 1 to 8 of 8
Thread: 69S MFI Stacks / 69E Throttles / 69 Fuel Lines
    Hi Guys,
    I have a set of 69S MFI stacks on a set of 69E throttles. The crossbar and fuel lines are included. One of the stacks is corroded badly. Asking $500 for everything.
    Here are some details Matt Blast from eurometrix.ws kindly sent to me.
    Early '69 throttles. The early ones had a different shape to the middle throttle arms which yours definitely have, and the very very early '69's had a 13mm flat on the nuts holding the arms onto the throttle shafts, which I think I see on your throttles. The throttles are E spec with the 32mm bottom. The stacks are '69 S as per the casting number. At some point the E stacks were replaced with S stacks which happened on occasion. The fuel lines are '69 only. Crossbar is '69-71.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Lower Price Bump
    $425
    Thanks - Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Hi. Are they still for sale ?????
    Hi derm.1785,
    Yes the parts are still for sale. Please let me know if you have any questions..
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Sorry Brad just got back from working away. Still for sale?????. if so how much and can i see photos of inside ports and butterflies, are they clean or worn, and i assume they are 2 ltr??
    thanks Derm.
    Hi Derm,
    The stacks are still for sale. They are 2.0 1969. Here are some more pictures. I will work on getting some of the ports and butterflies.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Junior Member
    Feb 2011
    Hello Brad,
    I would like to buy the parts you are offering,
    Please give me a call at 386 405 1249 I have a shipper number that you can use for shipping.
    Thanks David,
    I will call shortly.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
  1. FS: Many MFI parts off 2.4T 1972. pump, lines, stacks etc.
    By Fastdog911 in forum For Sale: 911 Parts
    Last Post: 05-19-2014, 10:14 AM
  2. replacing fuel lines: hoses and metal lines, 1967
    Last Post: 07-10-2013, 05:28 PM
  3. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  4. FS: Factory High Butterfly Throttles/Stacks
    By Matt Blast in forum For Sale: 911 Parts
    Last Post: 11-11-2010, 01:03 PM
  5. Machined MFI stacks, lines, S-Brakes, and a Puck
    By Unobtanium-inc in forum For Sale: 911 Parts
    Last Post: 03-06-2010, 05:02 PM
