Results 1 to 7 of 7
Thread: 906E slide pics
    Isn't chemistry always nano?
    Aug 2006
    906E slide pics
    Might anyone have any really good shots of 906E slides? I've searched here and pelican and found a couple that are kinda grainy. These slides clearly don't have the ribbing/sculpting of the later 3.0 RSR slides and have actuation out the end rather than the side.
    Im looking to maybe put the new CNC to work....
    Thanks in advance,
    t
    Sep 2006
    Eagle, Idaho
    Is this what you're looking for ?? ( engine shots from a 910 based in Seattle )
    ( sorry about the quality of the shots - foggy and dark, and I had no flash ).
    JZG
    Aug 2007
    Phila Pa. area
    906 slides
    The slides are not on an engine at this time, so I can take more pictures or measurements. The Magmesium casting is the mount for the injection pump.
    Mike
    pure porn those velocity stacks
    Aug 2006
    Holy pizza pie batman
    Wow! Thanks. Those are GREAT pictures.
    John... I'd hate to see what you can do with a flash. Amazing regardless.
    Lots of good detail to soak in.
    Anyone know if someone makes the air horns? They look like fiberglass.
    t
    Aug 2007
    Phila Pa. area
    they are fiberglass
    Mike
    Mike - I'm curious as to the numbers on the pump PES6KL60?120?LV???? and regulator EP/RLA 1-V8?? (if you don't mind sharing)
  1. Seats won't slide?
    By FL-Frank in forum Technical Info
    Last Post: 11-05-2013, 05:50 PM
  2. Slide Valve Injection System - 906E, 910, Maybe 911
    By mike curnow in forum For Sale: 911 Parts
    Last Post: 04-08-2012, 01:21 PM
  3. Slide valve question
    By Cornpanzer in forum General Info
    Last Post: 10-14-2009, 07:47 PM
  4. Slide valves are here
    By rst73 in forum General Info
    Last Post: 07-28-2009, 01:04 PM
  5. 3.0 RSR Slide Valves
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 02-04-2008, 04:55 PM
