Thread: Rookie accelerator pedal question
    Hi all-
    Rookie question; I'm trying to remove the carpeting from the pedal assembly. Brake and clutch pedal pull through the upholstered holes in the carpet okay but accelerator pedal requires (as far as i can tell) either the linkage to be disconnected from the pedal or the pedal to be unbolted from the floor. Or am i missing something here?
    Any advice would be greatly appreciated!
    Nick
    Have a '66 911
    Yep, just pop the rod out of the bottom of the throttle pedal. Pull hard.
    Tom F.
    Long Beach, CA
    Got it. Thanks. Much obliged.
  1. Pedal stop question
    By Bob Harriman in forum Technical Info
    Last Post: 04-25-2013, 08:51 PM
  2. pedal cluster to master cylinder question
    By vtrich in forum Technical Info
    Last Post: 12-17-2012, 08:46 AM
  3. Rookie Carb Adjustments
    By Kilgore Trout in forum Technical Info
    Last Post: 06-01-2009, 07:49 PM
  4. Accelerator Pedal question
    By TKO in forum Technical Info
    Last Post: 07-26-2004, 09:15 PM
