Results 1 to 10 of 16
Thread: Replacing front bumper deco
    Hi all-
    I'm attempting to replace my front bumper deco strip. Is there any way to accomplish this without having to remove the bumper itself?
    Any suggestions much appreciated-
    N
    Dec 2004
    I don't think there is anything to prevent you from doing this with the bumper still on the car. I believe you can get to all the nuts ok.
    Are you using an aftermarket replacement for the deco? If so, you will need to do quite a bit of fine tuning to get it to follow the contours of the bumper. I placed two 8" sections of 1" dowel in my vice and spaced them just a bit wider than the deco. I used this jib to coax the deco into the correct shape. Be patient.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Nov 2006
    S. F. Bay Area
    ...unless it's an S with front bumper weights which I believe (it's been years) conceals 2 of the nuts (?)
    Brian
    S Reg #1032
    Nov 2002
    Worshington State
    It will be far easier dropping the bumper - which is very easy - only 6 readily accessible bolts (4 in the trunk and one in each wheel well) to have to lie on your back in that cramped area with a light and have to futz them into position is not worth it. I give it one star out of 5 for difficulty - 5 being the highest.
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    My '68 non-S had the weights and the same issue. It is going to be a PITA regardless. I hope you are double jointed in your wrists and fingers or have a 5-year old who knows how to handle a wrench.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Does anyone have a pic of a weighted front bumper? Think mine may be one but not sure.
    Thanks.
    What year car is this?
    Jan 2008
    Eugene, OR
    I think '68 was the first year for the weights.
    John Thompson
    So obviously not a S but has the S deco strip on front bumper and now am wondering if the whole bumper isn't a replacement "weighted" S bumper? A picture of the inside of one would help.
    Obliged,
    N
  1. SWB/LWB Front Bumper Deco
    By juche_namja in forum Technical Info
    Last Post: 09-15-2013, 04:03 PM
  2. 67S front bumper deco
    By steve shea in forum Technical Info
    Last Post: 02-03-2011, 07:20 AM
  3. '67 S Front Bumper Deco FS
    Last Post: 06-28-2010, 06:02 PM
  4. Replacing Front Bumper Seal - DIY
    By TEC69E in forum Technical Info
    Last Post: 06-05-2007, 05:26 PM
  5. NOS S Front bumper deco
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-27-2007, 03:54 PM
