Results 1 to 7 of 7
Thread: braided fuel line
    Apr 2008
    westchester ny
    braided fuel line
    Gentlemen need some help
    ressurecting a 73 that was a cis car going to use some 42mm webers instead
    ned help with fuel hose sizes and where to purchase braided line
    all i can find is generic rubber
    what sizes vent is one size then there are 2 diff sizes that feed tunnel
    for feed and return
    i also would like some input as to fuel vent and feeding the webers
    thanks
    Tull
    87 cab
    80 sc track
    73 project
    Sep 2006
    Eagle, Idaho
    .......42 millimeter Webers ????
    We get the genuine braided fuel hose from Wurth, should be 7.5 mm ID for the return and engine bay hose, and should be 9 mm ID for the discharge line from the tank. (you can measure the steel lines in the tunnel to be sure) Besure to only use the norma clamps also from Wurth. They have a smooth clamping surface, don't use the generic worm drive clamps. They chew up the hose. Not sure what vent hose you mean, if you mean the vent hose in the front compartment you can get the correct vapor rated and color hose from McMaster-Carr. PVC yellow.
    Tull,
    I can help with the 7.5mm braided line. Black cloth braided or steel braided. Both are Cohline hose.
    You may be able to find it localy, if not I am happy to help.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Apr 2008
    westchester ny
    the 40 mm webers were ported to 42mm by paul @ performance
    sssswwwweeeettt
    have some tall manifold to go with , trying to get this thing up and running, within the next 42 yrs would be nice
    Brad thanks i will pm you
    Ed thanks for the info no need for vent hose if using the carbs believe that was all set up for cis application
    Tull
    87 cab
    80 sc track
    73 project
    The fuel delivery system would be best served if you could use the return to tank provision to allow the fuel to cycle through the carbs. (You would need to install an adjustable pressure relief downstream from the carbs to establish the 3.5 psi delivery pressure the Webers like.) This would be VERY effective to control fuel percolation issues a dead-end fuel supply system could have...
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Tull, when I said "vent hose in the front compartment" I meant the vent hose system for the gas tank. You'll still need some kind of venting there even with carbs. Sorry if I wasn't clear.
  1. Braided Fuel Line Size, 71T?
    By Stretch32 in forum Technical Info
    Last Post: 10-14-2012, 05:35 PM
  2. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  3. Early Steel Braided Cam Oil Line
    By Brad Davis in forum For Sale: 911 Parts
    Last Post: 10-13-2010, 07:43 PM
  4. Braided oil line hose, where to buy?
    By rcnagel in forum Technical Info
    Last Post: 01-14-2009, 06:00 PM
  5. Fuel Line
    By kissov356 in forum Technical Info
    Last Post: 06-26-2006, 12:45 PM
