Thread: WTB: Rear Relay Panel Mount
    Jan 2006
    Naperville, IL
    Looking to find one mount as pictured below.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Jan 2006
    Naperville, IL
    Looks like this is P/n 999-703-301-00 (Called "silentbloc" in the PET). Stoddard's search did nothing; Pelican says that this part has superceeded to 999-703-384-01 (Fuel Pump Mount 72-77) for $15.75; I will have to take a look at my fuel pump mount and see. As I thought they were different.
    -Andrew
    '72 911E
    S Reg #1074
    Atlanta, GA
    Can anyone provide the dimensions of this rubber mount used to mount the fuel pump? Thanks
    Jan 2006
    Naperville, IL
    Mark, Sorry for not getting back to you sooner; just getting back to this.
    Overall 20mm wide and 25mm in diameter as measured from the metal outer ends; if only measuring the rubber section-17mm widex 21mm dia.
    Below is the relay panel mount (broken) next to the MFI fuel pump mount. It looks to me that the MFI fuel pump mount has oversize metal washers on the outside of it. The photo above seems to be listed for later K-jet cars and visually looks like it could pass for the relay panel mount.
    -Andrew
    '72 911E
    S Reg #1074
    Atlanta, GA
    Quote Originally Posted by MoparBoy72 View Post
    No worries. thanks
  1. FS: '72 Relay panel
    Last Post: 09-30-2013, 10:10 AM
  2. Relay panel needed for MFI car
    Last Post: 01-07-2011, 08:49 AM
  3. WTB 69E or S MFI engine relay panel
    By ixxifan in forum For Sale: 911 Parts
    Last Post: 09-22-2008, 06:18 AM
  4. WTB: MFI Relay panel (engine bay) for '70
    Last Post: 06-01-2007, 12:00 PM
