Anyone here have a good source for Panasports? Looking for a 9x15 or something close to that size.
Bobby Smith
member #299
1973 914/4 2.8 ltr. (FTD winner 2008 Charlotte Parade) (sold)
1973 911 "Orangello"
1973 914/6 GT 3.2 "Crystal Blue Persuasion" (sold)
2011 Boxster Spyder
1973 911 E "E GO" Metallic Green
not panasports, I bought superlites.
http://www.vtoperformance.com/
Minilites are also available.
http://www.minilitewheels.us/default.aspx
go with minilites.
8 & 9" x 15" in stock ready to ship.
i got mine within 4 days from England!
nice guy aswell!
magnus
wow...they still look great..after all these yrs.
also look at Compomotive MLs...
and PS Engineering
Love the Minilites! I've been debating on a set for a while. I've read that they actually run wider than the size marked on the wheel. Can anyone verify this?
Magnus: What width are you running on the silver car?
-Kent
E911SR & RGRUPPE
'73 S Coupe #306
Does anyone have experience using their 15x7 wheels on a narrow body car? If so, what size tires are you able to get away with?
Jim Horton
Registry member #1682
1970 911T
1971 911E Targa
2002 Volvo v70 T5 wagon (black)
1955 Ford 2-door wagon
I've got some experience with this. I assume you are using 7x15 Fuchs with 4 3/4 inch backspacing. Keep in mind that not all tire manufacturers make the same size tire. In other words a Hoosier 225/45 will be wider than a 225/50 Kumho etc. etc. I used to like the 195/60 on a 7 inch wheel. It fits nicely and your gearing will be close to stock. Most any manufacturers 195/60 will work. For autocrossing you can fit a 205/50 Hoosier A-6 but the Hoosier 225/45 will NOT work with a 7 on my 911. I was able to fit the Hoosier 225/45 on 7R's with the proper spacers. Remember that your ride height will also effect the width of the tire you can use. My car is LOW. I have a friend that gets away with 225/45's on a 7 but his car is very stiff and quite a bit higher than mine. If you have any specific questions feel free to PM me.
Bobby Smith
member #299
2011 Boxster Spyder
Bobby can take the heat.
Tom
Early S Registry #235
rgruppe #111
