Have early 911 car- not driving for a few months wanting to hook up a safe trickle charger?
Have these in my '73S and '67 Malibu
http://www.acehardwareoutlet.com/pro...?sku=998016725
Hope this helps
I have used both the Sears one, and Battery Tender. The Battery Tender one is more robust, but also I've had a light go out on one after about 3 months (out meaning no longer working). They both work well.
Early S Reg #1809
I like the Battery Tender.
Cheers!
Frank Kohnen
Jupiter, FL USA
Registry Member #921
1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
2008S and all...I have 5ea CTEK "Multi US 3300"/12VDC and one CTEK 6VDC charger connected continuously 24Hours/day and I have used them for a few years now...No Heat generation and no misshaps, so far...I did use the "Schumacher"-units ,Chuck is mentioning, and they worked great also but I had two issues with slow heat increase and sever cracking of the black plastic housing and one failure of one LED...The cracking was to the point of exposing the "internals"...it made me nervous so I changed...The CTEK can be found on E-bay and is in similar+ price region...One of the 12V/CTEK had a slight "relay-flutter" but was exchanged and since then everything is fine...Good Luck.../ Lars...
Lars Wikblad...
Early 911 "S" Registry # 527
"R" Gruppe # 314
I've used the trickle chargers but have now switched to a larger schumaker charger that can charge the AGM type batteries. It also does trickle charging. It was about 100 at one of the auto parts stores.
I have used ctek's as lars has mentioned. Very happy with them.
'72T Coupe - Sepia Brown
Do AGM batteries require a different type charger?
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
Ctek does both. Other chargers perhaps are similar, not sure.
http://www.ctek.com/EN-GB/home/default.aspx
As long as the AGM-type battery is near-charged, most battery maintainers will do.
Sherwood
