Results 1 to 10 of 15
Thread: Newbee, SWB brakes question
    Junior Member
    Feb 2011
    Port Williams, Nova Scotia, Canada
    I posted this question on Pelican and "Flieger" suggested I ask on this forum.
    I don't like to be a pest so I joined up and spent about an hour trying searches. I can't say I have a clear how I should proceed. Here is the question;
    I am building a 68 SWB 911 from an 912 tub that I bought minus driveline. I am trying to decide what route to go with the rear brakes. I have parts from both a 72 and a 73 parts car including front S calipers which I will be using. What is the best and most reasonable option for the rears?
    1. Is the adapter piece I have seen on old posts still available? Could I use the 72 set up with an adapter ?
    2. Will the original (912) calipers with spacers and 944 rotors match the front S's?
    3. Stupid idea. Has anyone shortened the radius arms from a later car and gone that route? Then you would not need adapters to go with the 72 set up.
    I haven't seen any write ups on #3 so I assume there may be a good reason it is not practicle. Is there a standard route to go?
    Thanks, Greg
    __________________
    Dec 2006
    Las Cruces, New Mexico
    Easy way out use adapter and bolt up rear M calipers. Problem with that is no emergency brake. Your option 2 will not work because size of caliper piston's are too small as is brake pad 'L'. Can't comment on option 3. Another option find a rare pair of wide L early S rears and machine to accept M pad, these have piston size you will need to match up with front S calipers.
    Early 911S member #166
    Sep 2006
    Maryland
    Welcome to the forum, nice project.
    The E-brake hat on the later 911 brake rotors won't work with the SWB cars.
    Would be best to find the correct calipers, and use 944 rotors.
    Rob Abbott
    Junior Member
    Feb 2011
    Thanks Mark. Where do you source an adapter for the M calipers?
    Oct 2008
    Burford, ON, Canada
    I believe that this is the best solution:
    http://www.early911sregistry.org/for...(all-new-parts)
    Junior Member
    Feb 2011
    Thanks Dave. So worst case, I can get a solution for about $600 plus shipping from the UK. That's a huge help.
    1963 356 "Relic"
    1982 Sc 3.6 Conversion "Ruby"
    1968 911 recreation "Franzenstein"
    2005 Boxster S "wife's car"
    By the way, the brake guy here is Eric Shea at PMB Performance. His username here is "Neunelfer". He can set you up with restored calipers, new rotors, pads, fluid, and good advice.
    www.pmbperformance.com
    Oct 2008
    Burford, ON, Canada
    Greg, a local fellow was considering the same upgrade, so I got some quotes on it. I figured that I would get calipers only from the UK to save on shipping.Many of the other parts I would get from Eric. He and I work together on some things. I have a spare set of PMB restored S calipers on the shelf here that are surplus to my needs, and I could take trade-ins. My project is going to use the 908 clone calipers that he made up by copying my original. I suggest a full set of Porterfield pads. If you have complete front strut assemblies for the M and/or S calipers then I think you have some good solutions. Let me know what parts you do have, and what plan you are considering. I rebuild calipers myself, but for nice plated restorations I get Eric to work his magic.
    Junior Member
    Feb 2011
    Dave, sent you a PM
    1963 356 "Relic"
    Dec 2006
    Quote Originally Posted by scotiagreg View Post
    If memory serves me any 69-83 911 non turbo will have M rears they are easy to find not sure if all had 38mm pistons that's what you want. If you have a 72-73 parts car with S front calipers then you should have the correct rear M calipers with 38mm pistons. I fabricated my own adapters not really that big a deal but per previous no emergency brake. As for rotors with my adapter any 69-83 vented rear will work. With this setup eveything will be like factory S brake system including a 73 RS except EB. You can't go wrong with Alan and crew they have forgotten more than I know, same with Eric Shea. I would contact both.
  1. Are '65 and '68 brakes the same?
    By mshaver51 in forum Technical Info
    Last Post: 01-28-2014, 05:45 PM
  2. Replies: 43
    Last Post: 01-16-2014, 03:10 PM
  3. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  4. SWB rear vented brakes question
    By haycait911 in forum Technical Info
    Last Post: 12-11-2009, 05:11 AM
  5. What brakes are these
    By super9064 in forum Technical Info
    Last Post: 01-24-2008, 12:53 PM
