Results 1 to 9 of 9
Thread: 2.4S F serie Bosh injection pump
    Junior Member
    Oct 2010
    Belgium
    Hello to all members,
    I have a question about my 73 Targa 2.4S ; I bought the car to the first owner in Italy and it is all matching #'s.
    But I tought that the 2.4S have a 013 Bosh injection pump; I was surprised that mine is a 021 ....
    The car run great but it's just to know
    Thanks in advance for your help
    Gil
    Lightbulb
    Gil,
    They had both....
    About the first half of the F series S production was the #013 (dark in color) and the second half was the #021 (shiny in color)
    Hope this helps...
    Cheers
    Junior Member
    Oct 2010
    Belgium
    thank you very much Chuck, I'm reassured now
    I have #013 as the MFI pump for Euro 2.4S and #021 as the MFI pump for the US market 2.4S.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    You are correct John. The US Spec 021 pump had the 1/52R regulator & #061 space cam, and the Euro Spec 013 pump had the 1/41R regulator & #053 space cam.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Feb 2010
    San Francisco, CA
    I need to chime in here as I've also been wondering about my pump for a bit. My '73 S has the 013 pump. What are the major differences between the two (US/euro) regulators and space cams? Does this change output or the power/torque curve?
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Kent
    there are some minor flowing differences between this two units ...
    Philippe
    Feb 2010
    San Francisco, CA
    Thanks Philippe. I also gathered that there were some differences based on the emissions values in the CMA manual.
    -Kent
    Quote Originally Posted by martini911 View Post
    Kent
    Philippe
    E911SR & RGRUPPE
    '73 S Coupe #306
    Sep 2006
    Bend, Oregon
    Kent, Philippe is right on about the minor flow differences between the 021 & 013. The #061 space cam in the USA 021 pump is shaped a little different, very little, in a leaner idle and mid range to meet the USA emissions. Also the main rack adjustment is set up a little different than the Euro version. The only differents I can see is the main rack set up for the USA 021 is 1mm deeper @ 2000 rpm than the Euro 013 which leads to a little leaner A/F ratio. As far as HP/Torque specs. I can't find any difference in the manuals.
    Mark Jung
    MFI Werks
    R Gruppe #686
  1. FS: Bosh Fuel Pump 3 Connectors
    By 76911S in forum For Sale: 911 Parts
    Last Post: 01-07-2013, 03:33 PM
  2. FS: 911T MFI injection pump
    By Flieger in forum For Sale: 911 Parts
    Last Post: 01-09-2010, 07:25 PM
  3. 911 S injection pump
    By metshaper in forum For Sale: 911 Parts
    Last Post: 09-23-2009, 10:24 PM
  4. Injection pump
    By ydderf911 in forum Technical Info
    Last Post: 02-13-2007, 03:45 PM
