Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: can COA be this bad??
    the VIN number should have shown this is a Targa but whats the deal with
    those people? this is appalling.
    Richard aka le Zookeeper
    early reg #1128
    if the car had houndstooth,
    how about a wood wheel?would it be listed on the CoA?
    and whats a Kardex and how does one acquire one?
    early reg #1128
    There are, literally, dozens of little details that are easy to overlook. Especially if you are, say, 25 years old and not ensonced in Porsche. That is why a COPY of the Kardex is IMPOSSIBLE to beat!!! Thanks.
    -Allen-
    Dec 2008
    Woodland Hills, CA
    Don't they offer refunds?
    I had the exact same thing happen to me with my SWT, COA came back noted as a coupe......had to call and Kristen fixed it.
    Quote Originally Posted by EARLY911ZOO View Post
    Kardex = COA
    Used to be Kardex, many people still call it that. Now called COA. The "A", as you've pointed out, is questionable.
    Early S Reg #1809
    Senior Member Swiftmotoring's Avatar
    Nov 2010
    Bloomingdale GA
    This is usefull information, I have had similar issues... How do I reach Kristen? I have seen her name mentioned more than once and she seems to understand and be capable of corrections.
    Thanks!
    Marvin
    Marvin Waters
    25 Yr PCA Member
    10 Yr Early S Registry Member
    Oct 2008
    Burford, ON, Canada
    This is a Kardex:
    The Kardex is the original factory warranty record for a car.
    A COA is PCNA's interpretation of some of the information on the Kardex.
    If the interpretation is faulty, then the COA is incorrect. Many have to be returned for corrections, some many times.
    See this thread for various nuances on the Kardex topic:
    http://www.early911sregistry.org/for...p?66031-Kardex
    The Material color/type will indicate houndstooth. It will say pepita and /P if it is houndstooth. Similarly corduroy and /C for that material. The Kardex and COA generally only list options. So if the wood wheel was standard, then it is not listed. There is no substitute for knowing the standard features of a particular model. If you are a real expert then you will know what rules were broken and when. I am just an ex-squirt.
    Quote Originally Posted by fishman7 View Post
    Kirsten, okay I need to contact her, is she at PCNA?
    early reg #1128
    so Kardex is somewhat like a factory build sheet. I had an early Nova which came with GM's build sheet for the car along with the factory window sticker and additional options slip.
    early reg #1128
