Results 1 to 9 of 9
Thread: How do I separate the hazard switch
    I want to remove all the dash facia trim and I have done it before but I have forgotton how to separate the hazard switch so it can be removed. Please help I don't want to break the plastic
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Hi Clyde,
    The hazard switch is two pieces that come together in the middle. If you pull on it from the backside of the dash it will eventually come off. If it seems stuck, wiggle it a bit. It will come (I am pretty sure I don't have to say this, but don't pull it by the wires?)
    So its pull, wiggle and pull some more there is no clip arrangement stopping it from separating is there and no i won't pull on the wires
    Clyde Boyer
    No clip to hold the two pieces in place. Last time I helped a friend he had the same problem. It will come apart. The two pieces are plastic so they can't be rusted together.
    Hi Clyde,
    Here is a thread from the Pelican with a hazard switch. Perhaps the reason it is not coming loose is that you may be pulling on it to close to the middle. The two pieces come together unevenly like saw blade teeth. Maybe when grabbing it from the middle you are holding onto parts of both ends rather than just the rear. Try grabbing it more from the rear end so you know that you only have hold of the end piece. http://forums.pelicanparts.com/porsc...tches-71t.html
    A good nights sleep and I got it!!!....... so 3 pieces of trim removed
    Now to remove the heater controls I have to detach the cables from the heater box in the luggage area and undo the nut on the bracket at the back of the controls
    under the dash and then pull forward.......correct??
    Clyde Boyer
    To redo the dash you do not need to remove the complete heater defrost assembly. Just the chrome trim. Carefully lift up be carefull to not twist it.
    Cool thanks
    Clyde Boyer
    Got them both dash stripped of alloy trim thanks
    Anyone seen a website that sells reproduction alloy dash pieces in RHD???
    Clyde Boyer
  1. Replies: 1
    Last Post: 03-09-2012, 07:18 PM
  2. '71 Hazard Switch Removal
    By richemj in forum Technical Info
    Last Post: 11-20-2010, 03:18 PM
  3. WTB: Hazard Switch for my 71
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 10-26-2008, 11:28 PM
  4. WTB: 69 Hazard Switch Cap
    By NTW in forum For Sale: 911 Parts
    Last Post: 09-17-2008, 11:59 AM
  5. WTB '69 Hazard Switch
    By Fishcop in forum For Sale: 911 Parts
    Last Post: 06-03-2008, 01:13 AM
