Thread: Siezed clutch
    Dec 2002
    Birmingham, AL
    Siezed clutch
    My 73S has been sitting a long time in a dry, mild temperature garage with a battery maintainer. I finally got around to fixing some things on it and started it up today. It started easily in neutral but I can't get it into gear. I assume the friction disc is "frozen" to the fly wheel. I've had this happen before over the years but I've always been able to break it loose by starting it in gear. It won't work this time.
    Suggestions?
    BillM
    Senior Member aporschaguy's Avatar
    Feb 2005
    Great White North
    get it warm so it starts well, clear the way in front of you for 100 ft or so, shut it off, put it in 2nd, clutch pedal to the floor and keep it there, start car and as it gets rolling, go on and off the throttle a few times until it breaks loose.
    courtesy of John Walker (off Pelcan BBS)
    "He has all the virtues I dislike and none of the vices I admire."
    1971 911e
    1978 911sc Targa (Sold)
    1973 911 RSR (Clone)
    Dec 2002
    Birmingham, AL
    Thanks for the info. I was able to get help pushing the car out into the drive way. I had to deal with a slight upgrade so I couldn't get it to start in second. It finally started in first. I went about 150 yards up a steep hill before it broke loose. Works fine now.
    BillM
  1. clutch !@#$
    By Johan H in forum Technical Info
    Last Post: 08-26-2011, 09:16 AM
  2. new clutch
    By scargo70 in forum Technical Info
    Last Post: 04-19-2004, 01:16 PM
  3. 67S Clutch
    By bhaubold in forum Technical Info
    Last Post: 07-17-2001, 05:21 AM
