Hello all,
I fought for the last two hours to get the new rubber from International Mechantile in the track for the rear wing window. Any ideas?
Thanks, Tom
Hello all,
Thanks, Tom
Liquid soap and a credit card or bondo spreader and allot of patience
Don
Johnson's Baby Shampoo mixed with plenty of water and a rubber mallet to tap the rubber into place. I thought is was crazy when I read it but, after the same wrestling you have experienced it was the most successful method I tried. Get the rubber started then use the mallet to drive the seal on as you go around. Firm taps with the mallet worked just fine.
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
What about using glycerine instead of a soap/water solution? I'm adverse to putting water in places where it may remain some time. I like getting the rubber warm, and working it a little to increase pliability before installation.
Soak the rubber in hot water for 5 or 10 minutes, lube it up with hand soap, and then start working it around the window. I used a paint can opener with the 90 degree bend at the end to pry the rubber flange in the window frame. Worked like a charm and took about 20 minutes per window. Good luck.
Scott H.
1969 Coupe LtWt
1973.5 911T
I soaked mine in the tub in hot soapy water along with the frames and the used a rubber mallet to pop them in the grove. It was really quite easy took about 20 minutes.
Originally I wasted about 2 hours trying to do it by hand.
"He has all the virtues I dislike and none of the vices I admire."
1971 911e
1978 911sc Targa (Sold)
1973 911 RSR (Clone)
This task is THE most aggravating exercise I have ever faced while restoring a Porsche. I ended up paying someone $80 to do it on my behalf. We spent 3 nights doing ALL the above and said ....fu** it !!
[FONT="Lucida Sans Unicode"]
Curt Autenrieth
S Registry # 152
Porsches:
1.6L 2.7L
1.8L 3.0L
2.0L 3.2L
2.2L 3.4L h20 cooled
2.4L 3.6L air & h20 cooled
3.8L
Hello All,
Success due to this forum!!
This is what I did:
o Heated water in a pitcher in the microwave and soaked the rubber gasket for about 5 minutes
o Poured glycerin into my palm and rubbed it all along the inside of the gasket.
o Started at the square corner I pulled about 1/2 inch of gasket into the crease
o With that start, I ran the gasket parallel to the window and poured glycerin along the gasket and the window, I pushed the gasket into the window, and it almost fell into the window.
o Where there was trouble, I took a rubber mallet and tapped the gasket into place
The first one took about 20 minutes as I tried the credit card concept. The second one took 7 minutes.
Thanks to all that contributed to my issue. I just hope that others will learn from the forum like I did and prosper from it!
Tom
