Results 1 to 2 of 2
Thread: 930 Restoration Question
    A friend of mine is restoring a 1975 930 and asked me if I knew what color the cooling oil lines should be painted (or if they should be painted at all). I have no idea, so I'm resorting to the board in it's wisdom.
    Here are a couple of pictures
    Thanks for the help
    Henry
    Senior Member vipergruen's Avatar
    Feb 2007
    Milan, Italy
    I think that it should be unpainted only the trombone cooler, the oil lines that run under the car should be black.
    Anyway, i suggest to change the trombone with a later serpentine (from an SC or 3.3), the turbocharged engine needs much more cooling than the aspirated ones. Over here is a common improvement on the 3.0 cars.
    Is the car a Euro 75 one? if positive, can you Pm me the VIN? I'm trying to keep trace of all the ones that I find around.
    Best,
    Andrea
    Andrea
    Early S registry #1082
  1. Seat restoration question
    By NorthernThrux in forum Technical Info
    Last Post: 12-05-2023, 06:10 PM
  2. Restoration Question…1971 911T Targa
    By rliberty in forum Technical Info
    Last Post: 12-11-2013, 04:11 AM
  3. 70S suspension restoration question
    By spankie in forum Technical Info
    Last Post: 04-13-2012, 05:40 PM
  4. 118 driving light restoration question
    By CarmelSkip in forum Technical Info
    Last Post: 11-25-2011, 12:56 AM
  5. Restoration question
    By Bobboloo in forum General Info
    Last Post: 07-15-2005, 05:24 AM
