Thread: lower dash resto question for 71S
    With respect to the basketweave material on the lower dash which is correct: material uncut going from the right of the steering column all the way to the glovebox or the material cut on both sides of the radio (in other words right of the steering column to the radio, separate cut for the radio plate and then another section from the right of the radio to the glovebox)? PO had a metal plate over where he had the radio so in re-installing the original radio I want to make sure I have this right! Thanks all.
    Marco
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    My 73 has a separate plate, I wonder if the 71 was different. I've seen it both ways and I wonder if it was one piece with a factory installed radio and two piece if it was just radio ready option?
    Jan 2003
    NW Indiana
    Marco,
    My '71 was ordered without a radio (no antenna either). When I bought the car the previous owner had put a radio in the car from his previous '71S he had ordered while stationed in Japan (the radio was specific for the band there), but he also kept the original metal block-off plate with the basket weave material. He had rigged up a thin wire antenna taped to the inside of the windshield which looked like crap.
    I took the radio and antenna out and slipped the metal block-off plate in and the basketweave pattern matched the material adjacent to it perfectly. Who needs a stink'in radio anyway.
    Brian
    '71T
    R Gruppe #299
    Nov 2003
    Sydney
    Marco,
    This scan is from the white '70 brochure.
    It is actually a '69 dash however I don't see any reason for this basketweave to be altered between '69 and '71.
    The weave material looks to have no join marks between the right of the steering column and the lhs of the glove box lid.
    I don't see why there should be a plate there with no radio present.
    HTH,
    Dennis.
    S Registry member 536
    My guess is that if the radio was factory installed or if no antenna installation was done, it was one piece. If an antenna and radio prewire was requested they put the blank of plate separate. I have seen even 73's in one piece, so I think you can go either way. Just remember that if you change radios or add one later you'll have to change your covering again.
  1. FS: SWB lower dash pad
    By typ901 in forum For Sale: 911 Parts
    Last Post: 01-06-2013, 08:11 PM
  2. FS: SWB Upper and Lower Dash
    By ibmiked in forum For Sale: 911 Parts
    Last Post: 08-16-2011, 03:11 AM
  3. I will pay $250 for lower dash kneepad!
    Last Post: 10-04-2008, 04:59 PM
  4. WTB- Lower dash fascia trim
    Last Post: 09-25-2008, 02:17 AM
  5. WTB 69 911 Lower Dash Knee Pad
    By Bernie B in forum For Sale: 911 Parts
    Last Post: 10-08-2006, 09:02 AM
