Thread: A few questions regarding paint and undercoating
    From my observation:
    A '69 engine compartment is primer painted then a bumpy material is sprayed on, and then painted black....what is the bumpy rubbery material called? Is it available anywhere.
    Is it possible to buy a 1969 color in an spray can?..custom mixed possibly?
    Where can I buy the rubber tops for the light switch and rear window de-fogger, and the plastic rivets for the aluminum rocker cover.
    Thanks.
    wurth sells the coating. I got the rubber tops from Pelican, rivets are available from Stoddard or Sierra Madre
    For the remaining answer ,an old school auto paint shop can pump custom mixes into spray cans .In long beach Ca. the man is Gary at G.E. auto paints, minimum order is 2 cans ,usually about 30$ hes got some old paint codes or can mix perfectly by eye. tell him porsche Steve sent you
    Jun 2009
    West Hills, CA
    There are several types of undercoatings that you can use.
    I use Wurth SKS grey.
    it matches the original perfectly and the you can paint right on top.
    Most automotive paint stores will do spray cans now although I
    don't believe it will be the same paint without catalyst.
    Espo
    You fellows have been a big help! Thanks very much!
    Never heard of Sierra Madre before so I poked around their web site and saw a few things I need.
  1. 72 paint questions
    By jpnovak in forum Technical Info
    Last Post: 11-05-2013, 05:48 PM
  2. '69E Paint and undercoating questions
    By rdelmendo in forum Technical Info
    Last Post: 10-10-2013, 06:52 AM
  3. Questions on primer and paint...
    By StephenAcworth in forum Technical Info
    Last Post: 09-20-2013, 07:57 AM
  4. Replies: 4
    Last Post: 11-24-2012, 03:31 AM
  5. Paint help questions...please
    By John Straub in forum Technical Info
    Last Post: 11-08-2012, 05:36 PM
