Thread: Early Camber Plates and Bushes
    I have been mucking around with early camber plates and bushes for a while now and am becoming slightly confused.
    The very early 1965 cars with the fixed strut plate in the body used a pair of rubber bushes for isolation.
    I think that these bushes were carried over to the 65-68 camber plate and had part number 901.341.695.03
    The 1969 Camber Plate was slightly different but used either the same OR a similar bush.
    I have found two different types of bush see below.
    I think that the Left Hand Bush set is correct and the Right Hand set is supplied with a Koni insert and has become a common replacement for the correct bush.
    It could be that the 65-68 camber plate uses one type and the 1969 plate uses another.
    Does anyone know for sure.
    I know this seems picky but it would be good to know for sure
    The later camber plate with the one piece bush, IMHO, has different geometry and if used in early cars doesn't allow caster to be set correctly.
    and should, if possible be avoided for this application
    The later camber plate bushes are the same as the engine mount bushes, according to my source.
    Later one piece bush removed from camber plate - You can buy these in rubber from ER
  1. Replies: 2
    Last Post: 02-19-2013, 10:13 AM
  2. Early Camber Plate Rubber Bushes
    Last Post: 10-09-2009, 03:14 AM
  3. SWB Camber Plates
    Last Post: 08-07-2009, 05:54 AM
  4. Elephant camber plates, Recaro seat, BBS and more
    By cosley in forum For Sale: 911 Parts
    Last Post: 06-21-2009, 06:55 AM
  5. Camber plates : Weltmeister or Tarett
    By zaza in forum Technical Info
    Last Post: 04-17-2007, 06:37 PM
