Results 1 to 10 of 17
Thread: Help needed in identifying front bumper rubber
    Larry ljowdy's Avatar
    Nov 2006
    Ontario, Calif.
    I have a slight dilemma and I know someone has the answer. I have a 1973.5 911T with an "S" front bumper with the spoiler. The car was originally equipped with those hideous black foam front/rear bumperettes. I recently located and bought the rather rare black metal front and rear bumperettes that apparently were available of Euro models.
    The rears fit fine but the fronts are a bit narrower than the foam units and thus, the black bumper edge rubber doesn't fit properly. I'm not sure if the rubber has shrunk or if it requires a different piece. Can anyone direct me to the correct replacement rubber bumper edge material such as the 1 piece I've seen on other cars that I can either cut to fit properly or if it's in 3 pieces will fit the narrower metal bumperettes. In my parts book, it indicates that there is a narrow and wide version and I'm not sure what I have. Attached are photo's that should help in identifying what I need. The first photo shows the difference in width between the installed foam bumperette and the black metal bumperette. The second photo shows a bit more of the front leading edge rubber bumper material.
    thanks in advance.
    ps. If you have decent front bumper edge material that I need, let me know
    You have the wide S bumper trim. The rubber insert that looks to short is available new from Porsche. If you get stuck I have them in stock but I am in the UK and also not about for 2 weeks at the workshop as a new family member is due tomorrow.
    Alan
    Nov 2006
    Ontario, Calif.
    Thanks for the information.
    Another couple of questions. Do they make a solid piece of rubber that is continous. If so, then I could cut the rubber to fix the bumperettes for an exact fit.
    Do you have part numbers?
    thanks again
    The Netherlands
    Hi Larry,
    I think the one piece is 901.505.405.51. I you want the have them in 3 pieces then the middle one is 901.505.405.00 and 901.505.083.00 for the L/R sides. I would stick with original Porsche parts, the aftermarket rubber is different and sometimes doesn't fit as good.
    Best regards,
    Cees
    Nov 2006
    Ontario, Calif.
    Thanks Cees, Do you think I'd be better off buying the 1 piece and cutting it? Or, should I buy the 3 piece?
    Buy the single strip and cut it. As a tip, incase you ever need to do the rears, buy a single long front and cut it in half and do both rears.
    HTH
    Alan
    The Netherlands
    I agree with Alan...
    Cees
    Nov 2006
    Ontario, Calif.
    Thank you for the great information
    Nov 2006
    S. F. Bay Area
    Wow. I've always thought that the bumper guards (chrome, black-metal, or rubber) were 'notched' to fit over the rubber part of the bumper deco trim. I seem to recall seperate parts for cars with 'narrow' trim or the wider 'S' trim. Seems to be the case through '68, of course I realize you're dealing with a '73.5....
    Brian
    S Reg #1032
    It seems like all the original bumpers I've seen (other than the big bumper guard 73's) would fit over an uncut deco rubber. A hole had to be drilled through the deco for the top bumper guard bolt was all.
  1. Front bumper to body rubber question
    By merbesfield in forum Technical Info
    Last Post: 12-29-2013, 04:22 PM
  2. Help needed in identifying a bumper and bumperettes?
    By 55Outlaw in forum General Info
    Last Post: 10-21-2013, 06:15 AM
  3. WTB - Passenger side front bumper horn, no rubber
    By hesaputz in forum For Sale: 911 Parts
    Last Post: 12-01-2012, 12:03 PM
  4. FS-early 'S' front bumper deco with rubber
    Last Post: 02-10-2010, 03:00 PM
