Results 1 to 7 of 7
Thread: Recommended Door Skins
    Sep 2009
    Seattle
    Hello - does anyone have an opinion or insight in terms of getting door skins from Stoddard versus Restoration Designs? Are they from the same vendor? Does one fit better than the other?
    Any input would be much appreciated,
    Best,
    Alex
    Aug 2007
    Phila Pa. area
    I have aluminum door skins with old style porsche number tags on them. I have not mounted them on a door frame yet.
    Mike
    Hi Alex,
    I am not sure what ones stoddard sells but I 100% recommend buying factory porsche door skins. Try you local OPC (Porsche dealer)
    Alan
    Sep 2009
    Seattle
    Unfortunately they run about $1400 each. The Danish ones and the Restoration design skins are both around $300. I think I need to go that way - just wondering which is the better choice??
    Thx,
    Alex
    Junior Member
    Nov 2010
    Winnipeg Canada
    Mike Dejonge of Restoration Design:
    "Stoddards and Restoration Design get their door skins from the same source, Dansk"
    http://forums.pelicanparts.com/paint...ml#post5893055
    Hope this helps
    Tim K
    I have bought 6 door skins from Porsche recently and from memory they are around £193 each at todays rate thats $312.
    HTH
    Alan
    Jun 2009
    West Hills, CA
    Alex, I've used Dansk door skins ONCE!, they were crap!
    The demension on the top of the door where the belt moulding mounts
    is off by several mm. you won't be able to install the moulding.
    I put a pair on an RS I was building, took them off and tossed them!
    I would recommend original skins only ,or new doors
    John Esposito
  1. ALU Door Skins
    By sezme in forum General Info
    Last Post: 05-23-2014, 03:50 PM
  2. Door skins
    By tar356 in forum Technical Info
    Last Post: 07-27-2010, 05:02 PM
  3. FS NEW 911 door skins
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 03-19-2009, 08:26 AM
  4. Wtb Door Skins
    By 72911E in forum For Sale: 911 Parts
    Last Post: 01-21-2007, 09:10 PM
  5. AJ USA Door Skins
    By Paragon in forum Technical Info
    Last Post: 03-04-2003, 07:56 AM
