Results 1 to 10 of 10
Thread: Splish, Splash....oops I have a leak.
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    Question Splish, Splash....oops I have a leak.
    Howdy,
    I have a water leak and I am at a loss! My 68 Coupe after a lovely Seattle Monsoon, has about an inch of water on the rear floors.
    I just had the front windshield replaced and had the rear window reinstalled, both with factory Seals and done at Professional Auto Glass. No water is anywhere near those to window openings. It was leaking water through both before the fix. However, I'm still getting water after a heavy downpour. The rear passenger seat, also has water beneath it, not much, but a little.
    The floors were redone by the previous owner and I have also installed new door seals (later style) but noticed that there is some dampness at the base of the door sill on the carpet,however, given the volume of water, I'm still dumbfounded as to where it's coming from.
    Any helpful hints?
    Thanks so much in advance, and I am so desperately looking forward to summer!
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    Mine does the same thing and I can not find a leak anywhere.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    Mar 2006
    Louisville KY
    What I always do is take it to the car wash and get some one to sit inside while you mimic the rain. That way you can see if you have any water leaking around the door seals etc.
    Tony Proasi
    52 split window coupe
    Oct 2010
    Seattle, WA
    Since I fixed the seals, the car wasn't leaking under normal rain, however last night we had severe rain and that's when the water collected. I'll try the car wash and report back.
    Thanks!
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    Jan 2011
    DFW TX
    Mine both leak from behind the door panels... Even with well sealed plastic and good exterior rubbers. I learned a trick indirectly from Ed Mayo that I'm going to try next time the door panels are off. Instead of just a single sheet of plastic over the inner door, make a flap on the inside of the plastic at the big openings in the steel, so the flap laps over the inside of the opening, and the main sheet over the outside. Picture a tent. The flap acts as a deflector to keep water from getting between the main plastic and the steel inner door.
    If the rear jump seats have water then it must be coming from a higher scource, since the water couldn't jump up to the rear seats from the floor. Most likely from the rear quarter glass or the rear window. Take out the rear parcel deck panel (probably needs drying out anyway) and do what Tony suggested. This way you can see if it's coming in around a seal. If some of the water is coming from the front look at the fresh air drain box under the vent in the cowl. Follow the vent tube down into the smuggler's box to see if it's been damaged and the water can enter the floor from the bottom of the smugglers box. Especially if the car ever had AC installed.
    Thanks for the Kudos Mike, but actually that was the way originally done by Porsche. I just make sure to put them back that way.
    Nov 2002
    Worshington State
    If you have a sunroof - check the seals and drains. If you don't have a sunroof - check all seals and install a drain.
    Feb 2003
    Los Angeles
    Quote Originally Posted by M_deJong View Post
    Reviving an old thread, because my doors are leaking water also. Can someone post a photo of the description given above for installing the inside plastic sheet correctly?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    I may have some pictures at work, I'll try to remember to bring them home.
    Feb 2003
    Los Angeles
    Thanks Ed. I look forward to your photos.
    Bert Jayasekera
    R Gruppe #167
  1. FS: SWB Splash pan
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 03-05-2013, 02:41 PM
  2. Splash Guards
    By gsjohnson in forum General Info
    Last Post: 02-21-2013, 11:48 AM
  3. SWB Splash pan
    Last Post: 11-03-2012, 08:54 AM
  4. OOPS! 911 parts car
    By plumber in forum General Info
    Last Post: 01-16-2012, 04:38 PM
  5. Door Lock/Actuator ->oops/kaboing/what was that spring?
    By karlusmagnus in forum Technical Info
    Last Post: 04-10-2007, 02:19 AM
