Results 1 to 7 of 7
Thread: 69S Compression Test Results
    Nov 2010
    Darien, CT
    Hi,
    We did a compression test today on our 69S and the results seemed odd to us.
    On the right bank:
    #1 135
    #2 135
    #3 140
    On the left bank:
    #1 160
    #2 170
    #3 166
    Never seen this before - such a large difference between banks. We retested it twice to make sure we didn't make an error. Engine supposidly has less than 1000 miles since rebuild. Have a stack of receipts confirming this. Has anyone seen this before?
    Scott
    Perhaps the cams are not timed close enough to each other. There is a spec for the lift when setting one cam, and the other should be at the same lift and within that spec. It is a few tenths of millimeters, IIRC. Perhaps you have a few too many tenths of difference, leading to the different compression patterns.
    Dec 2006
    Las Cruces, New Mexico
    I think Max is on to something.
    Early 911S member #166
    Does it drive in circles?
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Nov 2010
    Darien, CT
    I wish it did. Between this and the bad bearing in the tranny it doesn't really move much at all.
    Thanks for the responses.
    sometimes I have done a compression test when the throttle blades are closed and it effects the reading, with the overlap the readings may also change a bit depending on how fast you spin it over, ie' the difference between static and dynamic compression. S
    Yes, the throttle linkages could be mis-adjusted so that only one side is getting full throttle. I have also heard of people finding that they have two different cams in the engine, though that is usually when buying a used project engine, condition unknown.
  1. cost of compression test/leakdown test?
    By aknatar in forum General Info
    Last Post: 06-07-2007, 09:22 AM
  2. Le Mans test results
    By songhoh in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 06-04-2007, 06:21 AM
  3. Compression test results, need help
    By Eddmond in forum Technical Info
    Last Post: 10-06-2003, 05:00 PM
