Thread: Body paint for a 1972
    I know this has been discussed a million times and I did a search but can someone confirm that the wheel arches and underbody af a 72 is painted black, I know the trunk is body colour and the engine bay is black over the body colour but I just need to confirm the rest of the body please
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Right you are Clyde, bottom and arches are black.
    Satin or matt??
    Clyde Boyer
    May 2005
    Oroville, CA
    It measures usually near 67%. ANY 60-70% would be close. That is as 0 is theortical non reflective and 100 is gloss.
    Manufacturers don't use a standard. But semi-gloss is usually glossier than satin; matt is usually less. Even flat has a number about 10% or so.
    In other words; satin is close. IMHO
    H
    May 2005
    Oroville, CA
    Chassis Black
    Clyde,
    Sorry for the long explaination, but it took a while to find out the color was easy.
    The black is the same as you would use in hiding the body color in the interior; like when you spray the seat belt anchors and seat slide bases.
    After all that matching when we went looking for a brushable paint (concourse tie breaker) for the doors we found a product called "Chassis Black" that was right on.
    H
    Thanks Harvey
    Clyde Boyer
  1. Paint body color H4 rims
    By frankmar in forum Technical Info
    Last Post: 11-06-2013, 07:47 AM
  2. Replies: 0
    Last Post: 01-08-2013, 01:03 PM
  3. Paint/Body Suggestions for 67S in Nor Cal or Other
    By joshkras in forum General Info
    Last Post: 08-11-2009, 02:01 PM
  4. Paint and Body Work in L.A. Area
    By J-P in forum General Info
    Last Post: 08-04-2006, 07:04 PM
  5. Best LA area paint & body
    By boxster03 in forum General Info
    Last Post: 09-11-2005, 06:02 PM
