Results 1 to 9 of 9
Thread: Fact or Fiction
    Aug 2005
    VA
    Fact or Fiction
    Urban ledgend, in my opinion, is that a less restrictive exhaust system (sport muffler) will reduce HP and torque in an MFI equipted car.
    I just don't see how this can be. Free flowing air in and out has to be better than working harder to push air out.
    I need to buy a new muffler and am thinking of a sport muffler.
    Does anyone have any proof of more restriction = more HP.
    73 911 S
    Backpressure: The myth and why it's wrong.
    I. Introduction
    One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Engines need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
    II. Some basic exhaust theory
    Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
    III. Backpressure and velocity
    Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
    The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
    Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
    IV. So how did this myth come to be?
    I often wonder how the myth "Engines need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
    V. So why is exhaust velocity so important?
    The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Aug 2005
    VA
    WOW, that is some response, Thank you!
    So in my case a less restrictive muffler will not have an adverse effect on performance as I am not changing the headers. Once the exhaust gets to the muffler all pulses are lost and less restriction is a good thing.
    If my thinking is wrong, let me know the error in my logic.
    Many thanks again
    Chris
    73 911 S
    Dec 2008
    Woodland Hills, CA
    Just because you increase pressure, it doesn't necessarily mean that you increase volume.
    Apr 2003
    Portland, OR
    Quote Originally Posted by sithot View Post
    Stock muffler on an MFI car works about as good as it gets.
    Tom
    Tom:
    Or as we find over and over again, when it comes to engines, the Porsche Engineer did not leave any easy hp on the table.
    Harry
    Member #789
    2009 MB C300
    As I've posted before....... Pre 2003, when my 2.4S engine was still stock, I tried two different 'sport mufflers' within about 5 years or so (An AJ 2 in 1 out Sport/ and a Monty 2 in 1 out MFI Sport)... and both with the same results. Not disagreeing with Boxster, both systems did indeed seem to give me more top end; however both took away enough bottom end and mid-range/transition that I needed to 'fatten' an already rich system so much that I finally giving them up and put the stocker back on. My 2.4S street motor was not big on torque in the first place, so I figured I couldn't give up any 'coming out of the turn snap' with any of the top end gain I was getting.
    Again, this was is a street car that I track only about 2 times a year......
    Now that my old 2.4S is a 2.7RS+ spec motor, I will admit I have not tried another sport muffler.......... who knows????
    Maybe with the extra torque of the 2.7 it might be a win, win...
    Just .02 of a little personal practical experience.......
    BTW- I wish I had the difference in money for what I bought those two sport mufflers and what I was able to sell them for........
    BTW II - And a tip - The stock muffler I have on the car now is a '74/some '75 type with the later valence bent exit pipe cut off and an Early exit pipe welded on.... The early-mid-year mufflers perform identical to the early stocker, there's still a lot of them around, AND a lot of them were stainless.......... AND I bought mine from Roger Grago, so it has good karma.......
    Cheers
    Chuck's experience mirrors my own. With a 2.7 RS MFI engine equipped car on a rolling dyno, the best midrange HP/torque figures were achieved with a stock Leistritz exhaust. We also tried a sport muffler and a Triad exhaust.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    Aug 2005
    VA
    Great Thread on the muffler comparisons. Especially since my motor is almost identical to the one used for the testing (higher compression, relatively otherwise stock 2.4 s)
    According to the dino tests of 6 mufflers the way to go is with the stock sport muffler. Incidentally this is what is currently on my car but has a dent in it.
    One strange aspect of the dyno tests was a 10 HP gain by taking the air cleaner off. I thought the air cleaners were non restrictive and pulled air from a cold portion of the engine compartment and were thus beneficial.
    Chris
    73 911 E +
    I have always LOVED the SOUND of my sport muffler!
    Peter Kane
    '72 911S Targa
  1. FS: 1969 Fact Book Brochure, excellent
    By VA_alfa in forum For Sale: 911 Parts
    Last Post: 01-27-2014, 01:17 PM
  2. FS: 1969 Fact Book Brochure 911 S,T,E
    Last Post: 11-16-2013, 06:49 AM
  3. 1969 911/912 Fact Book for Sale
    By peters911s in forum For Sale: 911 Parts
    Last Post: 04-16-2009, 04:23 PM
  4. 1969 911 Fact Book Brochure
    Last Post: 05-27-2008, 12:02 AM
