Results 1 to 8 of 8
Thread: Twin plug adaptor
    Feb 2011
    Northern VA
    Twin plug adaptor
    I picked this up a while back at a swap meet for $100 bucks. I ended up using a different twin plug setup. Whoever made it did a fantastic machining job and an even better anodizing job. However, I could not tell you for which distributor, cap and rotor it was designed for. If I could get a hundred bucks for it and it went to a good home (non ebay reseller), I would be happyIMG00075-20110317-0932.jpgIMG00075-20110317-0932.jpg.
    Hello Geneulm,
    IŽll take it if it fits my Marelli distributor cap and an early type of distributor. I just bought my "doppelzuendung" cap and rotor so I would like some measurements before I can decide. Do you have the inner and outer diameter and the heart to heart distance between the outer 3 holes please.
    Thank You,
    Chris
    Feb 2011
    Northern VA
    Chris,
    Please private mail me and I will get these measurements for you in the AM (the part is sitting on my office desk).
    gene
    Feb 2011
    Northern VA
    I do have some measurements... hopefully some expert on this forum will ID what distributor it goes for.
    Inside diameter: 80mm. There are several ridges, but this is where the set screws are.
    Outside diameter: 110mm
    Outside diameter where the cap fits on: 98mm
    Total thickness of the piece is 13mm
    Helpful?
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    I have the same twin-plug adapter as the one you posted except for the cap fit O.D. size. This adapter will fit the 3.0 SC & 3.2 distributors with that 80 mm O.D. The one I have has the O.D. for cap mounting at 96 mm and fits the twin-plug Bosch cap. Yours is 98 mm for the cap so that might be for the Marelli cap. All other size's you posted are the same on mine.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    The inside diameter of my Marelli cap is 96 mm so I am afaid it will not fit your adapter. Thanks for the measurements.
    Succes with the sale.
    Chris Mulder
    Sep 2006
    Bend, Oregon
    geneulm, Check that cap O.D. size on your adapter again. If the Marelli is 96 mm and the Bosch is 96 mm what would the 98 mm O.D. fit?
    Mark Jung
    MFI Werks
    R Gruppe #686
    Feb 2011
    Northern VA
    Measured again. The OD of the piece that the distributor clamps to is 98mm. It wouldn't take much to chuck it up and spin 1mm off it. I will even knock the price down to $75 to pay for it. (I'd do it myself, but my chuck isn't large enough to fit.)
  1. twin plug
    By raspy2point2 in forum Technical Info
    Last Post: 01-05-2014, 07:22 PM
  2. Twin plug cap
    By Andy 74 in forum Technical Info
    Last Post: 02-28-2013, 07:37 AM
  3. Twin plug with 1 or 2 MSD box ?
    By RS-GT in forum Technical Info
    Last Post: 06-12-2010, 05:42 AM
  4. Replies: 7
    Last Post: 02-15-2007, 09:31 PM
