Thread: Pic of 73S throttle lever parts
    Atlanta, GA
    Can someone post some pics of the parts, supposedly a plastic part, that would be inside the tunnel and connected to the throttle lever for a 73S? My mechanic says there is some plastic piece that my car is missing. Just trying to figure out what parts I need. Thanks
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    Is it the part connected to the red knob handle gas lever located between seats ?
    valve lever 901 424 317 00
    Manu
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Mark,
    Here is an image that may help.
    You will need to take the hand throttle lever off the shaft.
    You will find several (4+) cork ‘friction gaskets’ that are probably failing from age.
    Have those available.
    The white plastic piece (violet arrow) is slotted and simply slips on & off the throttle rod.
    Once you have the hand throttle lever assembly off the shaft, you can remove the circlip.
    Don’t try thin in the car unless you have a bag of spare clips.
    Adjusting the ‘barrel stop’ on the throttle rod is an easy trial-&-error process.
    Do not loosen the set screw much (only enough to force the barrel to move on the rod.
    There should be some free-play at the hand throttle when ‘off’ and the rest of the accelerator linkage is on the stops at the MFI.
    This might be a good opportunity to go through the throttle linkage from the accelerator pedal to the MFI cross shaft (do not adjust linkage at any of the MFI).
    Search Pelican as I have this in detail. http://forums.pelicanparts.com/searc...archid=6530758
    Have your magnet-on-a-stick and grabber tools handy for this.
    It is much easier with the driver’s seat removed.
    Best,
    Grady
  1. 67s heat and throttle lever both on parking
    By MarkS in forum Technical Info
    Last Post: 02-19-2014, 04:29 PM
  2. Manual Throttle Lever
    Last Post: 10-05-2012, 11:35 PM
  3. WTB: Hand Throttle Lever and Knob
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-08-2010, 10:43 AM
  4. Hand Throttle Drag Lever needed.
    By aporschaguy in forum For Sale: 911 Parts
    Last Post: 07-16-2010, 09:44 AM
  5. 914/6 throttle lever mechanisim
    By Cliff in forum General Info
    Last Post: 07-02-2008, 08:53 PM
