Thread: WTB MFI fuel line banjo
    Oct 2005
    wash dc/ los angeles ca
    Hello I need a suppiy side banjo w/male end ,fits MFI pump body on supply side,not
    certain of mm size but slightly smaller than those on fuel filter canister...
    Thanks any help appreciated,I believe they are the same '69-'73 contact Bert
    ecrobinson1726@msn.com
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Bert, The fuel filter canister banjo fittings are 14mm so you need the 12mm banjo fitting. The 12mm banjos are used on the late 71 pumps on up. The 14mm banjo fittings were used on the 69 to 71. I have a 12mm banjo bolt with the fuel fitting in stock. $20 for the set plus shipping.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Oct 2005
    I was hoping you might see this ,I had just read your response on the bird,email sent Bert
  1. Bendix Fuel Pump Banjo Kit
    By Brad Davis in forum For Sale: 911 Parts
    Last Post: 02-05-2015, 01:58 PM
  2. WTB: Fuel Banjo Fitting
    By drwhosc in forum For Sale: 911 Parts
    Last Post: 03-17-2014, 07:47 AM
  3. Replies: 4
    Last Post: 12-02-2013, 01:09 PM
  4. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  5. Fuel Line
    By kissov356 in forum Technical Info
    Last Post: 06-26-2006, 12:45 PM
