Results 1 to 10 of 10
Thread: Targa Bar Fitting...need a picture.
    My game..saving Porsches FHernand's Avatar
    Jan 2006
    In the process of putting together a targa cover and need a close shot of the area I have circled in the picture below. If you have a targa and can share a close up shot of the bottom corner where the chrome qrtr molding meets the targa bar I would be greatful.
    VINTAGE SPORTSCAR RESTORATIONS INC.
    www.vsrestorations.com
    Phoenix OREGON
    Freddie Hernandez
    freddie@vsrestorations.com
    (541) 535-3304
    www.facebook.com/VintageSportscarRestorations
    I'll fix you up tomorrow.
    Rob
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Jan 2006
    Rob, thanks.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Detail from unmolested original car. The stainless cover fits inside the trim. Sorry don't have a good shot of that. Thanks.
    -Allen-
    Jan 2006
    Thanks Allen. Rob emailed me an exterior picture of an unmolested rear window area. When one changes the rear window targa seal, targa bar cover rear seal and quarter trim moldings, it takes some customizing to get all the exterior moldings, gaskets and targa bar to fit like the factory had them due to the variation of thickness on new items. I think we have it all button down now. Thanks
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Targa Bar Fitting...need a picture. Your Message
    Freddie, if its any help here's one I took today, customer car we recently finished, waiting for pick-up.
    Jan 2006
    Great, thanks Ed. Here is a picture of what I believe to be the correct set-up. The orange chrome trim should fit snug up against the targa cover. The chrome trim piece edge is cut at an angle to fit the targa cover angle (marked in purple). The targa bar seal marked in red, sits behind the chrome trim piece. In order for the chrome trim piece to slide up against the targa bar, the backside edge of the seal marked in red must be cut at an angle making the chrome piece slide over the seal and not look like it's bulging out or worse yet, bent. Because it's such a tight area and so much variation in thicknesses, it's a challenge to have everything just perfect. The window seal edge marked in green, is also cut at an angle to match that of the targa bar cover. I have had to slice some thickness off the targa window seal in order for the targa bar cover to slide behind the quarter trim chrome. When the factory was slapping these rear targa windows on at the assembly line, they had down to a science and they call came out perfect...some day mine will be the same.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    I've only dabbled in fitting the seals and top. I had a '70 Targa in Fla in the Navy around 1975. Leaked like crazy. Bought EXPENSIVE new seals, just putting them in was difficult. Still leaked some and the Targa top set high. I'm told, for example, that BIG Ron at Jerry Woods is a master of "tuning" the seals. Like you've found on just fitting the Targa loop, there is much MORE than mets the eye to these hand-built cars!
    Toward the end of LWB cars, Targas were VERY popular. Rust prone due to leaks, they are not easy to restore..right!
    -Allne-
    Quote Originally Posted by FHernand View Post
    We had a bit of debate on this fit and ended up with what we thought was a good fit based on what looked to be original marks on the aluminum end piece of the trim. At the time we couldn't find any dependable, close up, known original pictures of this area. At any rate I like your solution also. But we're NOT going to do it over!!! LOL
    Jan 2006
    I'm with you Ed..but let's keep perfecting the process...
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
  1. Argus Fitting
    By Brad Davis in forum Technical Info
    Last Post: 12-15-2016, 04:50 AM
  2. Fitting Ampliluxes
    By geneulm in forum Technical Info
    Last Post: 03-08-2012, 04:28 PM
  3. WTB: Fitting for Oil P sender on RSR
    By Jim Calzia in forum For Sale: 911 Parts
    Last Post: 02-12-2009, 12:56 PM
  4. Can anyone tell me what the heck this fitting is?
    By Eminence Gris in forum Technical Info
    Last Post: 04-22-2008, 08:15 AM
