Results 1 to 7 of 7
Thread: Looking for a measurement
    See the pic. I'm looking for a reasonably accurate measurement of the distance between the two points indicated on the 65-73 front anti roll bar lever shown, i.e. the distance from center to center. Should be 6--8 inches or so. Anyone have one of these levers lying around, or maybe have a car up in the air and accessible? And thanks to someone for the fine image I stole! Jim
    jhtaylor
    santa barbara
    The Tarett ones are nearly spot on 6 inches center to center at the softest setting. This dimension should be the same as the one you are looking for, since they are made to fit the same suspension geometry. The 6 inch length gives the optimum kinematics, and is why you should run the bars as soft as possible, using a bigger bar rather than a shorter lever, leaving the lever for fine tuning.
    I take it you have the Carrera under A-arm style now, and that is why you cannot measure for yourself?
    stock bar on my '67 is 118mm.
    Interesting. 4.6 inches.
    I should have mentioned that the bar is not on the car- so I guess the softest setting is not the optimal lever position.
    Oct 2005
    Minneapolis, MN
    I'm getting 119-120mm
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Max, yes, I have the "simplified" bar.
    Thanks to all. If that arm is 118-120 as you measure it, then my 22mm "simplified" under the control arm bar is roughly equivalent to an 18.2mm thru the body bar by my calculations. There is one other dimension that would alter this... the distance from the control arm axis to the sway bar attachment point. I've been using 160mm. If that distance was actually about 133mm with the earlier thru the body bar, then the ttb equivalent of my 22mm "simplified" bar is closer to 20mm. So I guess I need that number too.
    jhtaylor
    santa barbara
  1. Chassis measurement diagram
    By Harvey Weidman in forum Technical Info
    Last Post: 02-20-2011, 01:12 PM
  2. 72 oil filler location diagram / measurement needed
    Last Post: 08-09-2009, 03:23 PM
  3. Momo Wheel Measurement
    By 50/50 in forum Technical Info
    Last Post: 10-14-2008, 10:13 AM
  4. RS Flare Measurement
    By CamBiscuit in forum Technical Info
    Last Post: 07-23-2008, 02:52 PM
  5. Antenna Hole Measurement Help?
    By FHernand in forum General Info
    Last Post: 11-06-2007, 06:15 AM
