Results 1 to 10 of 17
Thread: Cant shake off exhaust smell in car.
    Feb 2007
    BKK,Thailand
    Hi,
    My 66 keep getting exhaust smell in the car, it happen only when i travel above 60+ MPH then brake or slow down. The strong exhaust smell would then enter the car. At normal drive around town or steady speed it's all fine.
    -I have all my heater remove.
    -seal the heater opener by the foot well on both side.
    -I have no heat exchanger.
    -I have center GT3 style M&K muffler. (could this be the problem with some sort of aerodynamic back flow?)
    -All rubber seal are new.
    -I have custom air condition. Two condenser. One is at the front left fender, second one is rear left fender. ( i try testing the smell from aircon vent seem like the smell is not coming from there.)
    The smell seem like it's entering from the rear passenger.
    not sure where else to look, any idea would be greatly appreciated.
    best regards
    tenn
    EarlyS #1342
    I assume you saw this?
    http://www.early911sregistry.org/for...ater-on-sleepy
    maybe have a good look around the engine tins to see if there's any chance of air being drawn from underneath the car.
    Two possibilities to check Tennster. Do you have the rear window defroster outlets installed, and if so have you sealed them off from the engine compartment, and secondly did you seal off the holes that were for the heater control valves under the rear body section.
    Feb 2007
    BKK,Thailand
    ok thanks guys,
    yes i saw that thread and it really give me concern, i always drive with my window open to make sure i get plenty of fresh air but the smell still very strong.
    I dont think i have rear window defroster but i will double check and report back.
    cheers
    tenn
    EarlyS #1342
    How long are your exhaust tips? do they clear the bodywork?
    +1 with RStarga,
    I was telling Tenn about the length of the exhaust tips.
    See the turbulent created behind the 924.
    http://thaiporsche.shutterfly.com/action/
    The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
    86, 930
    70, 3.2
    67, 911
    Feb 2007
    BKK,Thailand
    David,
    it does but not by a whole lot, here is the picture i will make measurement tomorrow.
    thanks
    tenn
    EarlyS #1342
    Shift coupler tunnel? Are all the rubber (3?) bits good? If not, can fumes be entering through the shift coupler tunnel?
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Feb 2007
    BKK,Thailand
    Quote Originally Posted by bob tilton View Post
    Hi Bob
    just recently replace them because i though the same.
    keep it coming
    cheers
    tenn
    EarlyS #1342
    Feb 2007
    BKK,Thailand
    Ed, Raj,
    This could be it i just notice the rear window vents. I guess that's also rear window defroster?
    does any body have picture of these area? so i will know exactly where to look and compare.
    thanks guys
    will investigate!
    cheers
    tenn
    EarlyS #1342
  1. Gas smell
    By EA911 in forum Technical Info
    Last Post: 10-21-2009, 11:35 AM
  2. exhaust smell in cabin
    Last Post: 09-19-2008, 05:04 PM
  3. Factory 20 Mile Shake Down Drive
    By boxster03 in forum General Info
    Last Post: 11-01-2007, 04:38 PM
  4. Exhaust Experts Unite - need help for racing exhaust !!!
    By RPMClassic in forum Technical Info
    Last Post: 09-06-2006, 06:06 PM
  5. Gas Smell
    By jaudette3 in forum Technical Info
    Last Post: 08-25-2003, 09:02 AM
