Results 1 to 2 of 2
Thread: Center lube fitting
    Isn't chemistry always nano?
    Aug 2006
    Center lube fitting
    Can anyone please tell me what the thread type of the 901/01 center camshaft lube fitting is... The male thread that goes into the cam cover.
    It appears to be M10x1, but it aint cause its tapered... Logical since there was no sealing ring like the M12x1 fitting on the case for the cam oil feed.
    It also doesn't look like BSP, too fine.
    Any help would be great!
    tadd
    I believe it is just a 10 X 1 tapered fitting, hence the tapered threads in the cam housing. I think it is very close to a 1/8th SAE pipe thread.
  1. FS: Center Lube Cam Lines
    By Brad Davis in forum For Sale: 911 Parts
    Last Post: 01-03-2018, 07:13 AM
  2. FS: center lube cam boxes
    By geneulm in forum For Sale: 911 Parts
    Last Post: 05-24-2013, 05:55 PM
  3. FS; center lube cams
    By otto in forum For Sale: 911 Parts
    Last Post: 05-10-2012, 12:12 PM
  4. 65` center lube engine
    By Cliff in forum General Info
    Last Post: 05-08-2012, 06:53 AM
  5. FS: New Center Lube cam seals
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 06-26-2008, 06:18 AM
