Thread: A bicycle carrier for "early" 911 Targa's.
    Junior Member
    Dec 2010
    Monroeville, Pa
    I have built a custom bicycle carrier for my '70 911 Targa. The pictures give you an ideaof how the carrier looks.
    I noticed that the engine lid hinge and the bumper over-rider line up nicely for mounting of a Yakima or other rail.
    The pieces that are needed are:
    1 A spacer between the grill on the engine lid and the rail.
    2 An attachment piece between the lower end of the rail and the bumper over-ride. This shouldbe a quick disconnect
    3 A set of pieces to secure the fork of the bicycle to the rail.
    4 A rod between the bicycle and the other bumper over-rider, also with a quick disconnect.
    All these pieces can be seen on the pictures. The fork is fastened with a front wheel release as used on the bicycle, the lower end also uses a (shortend)quick release. The rod has quick disconnect "ball socket" connectors on both ends.
    If you have an interest, I will send drawings of these special pieces to be custom made, best by a machine shop, and further information.
    The "set-up" fastens the bike very solidly on the car.
    Pretty cool!
    Peter Kane
    '72 911S Targa
    Looks good, I take the front wheel off my bike, put it in the trunk and then put my bike in the back with plenty of towels.
  1. 15" tires for early rsr w/9"-11"x15" fuchs
    By rennmeister in forum Technical Info
    Last Post: 07-06-2016, 05:04 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-09-2012, 07:53 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  4. Replies: 0
    Last Post: 09-27-2007, 03:33 AM
