I am getting rid of my collection of spare parts-the wife says the house is overwhelmed. Contact me if you see something you want or even if you are interested in a related item. I probably have it. I am selling the following now:
1. (2)Complete Carrera pressure fed tensioner kit. NOS except for tensioners which are used-$450.
2. (5)3-pin CDI units 12 MO warantee-$350, with rebuildable exchange-$225.
3. (5)Gated short shifters-Porsche body(05 or 06) and Porsche internals with
custom Seine gate-$250. Add $35 for knob and $19 for new boot.
4. (4)SC/Carrera brass 28 tube cooler(good shock mounts, short oil lines, and mounting hrdwr)-$350. Billy Boat (B&B) oil coolers (2) with fan set up for front right fender $550.
5. Mocal Oil Thermostat AOT2 -$100. AN12 fittings for Mocal-$20, SC/Carrera Oil Thermostat-911.107.163.OR (good threads)-$250.
6. 1970-2 911 flexible oil Lines (ask)
7. (1)180 MPH Carrera rebuilt speedo-$450.
8. Complete MFI fuel injection systems*
(4)2.4L 911E (72/73) $2495 Plastic stacks
(1)2.2L 911E (70/71) $2595 Mag. stacks
(1)2.0L 911E (69) $2295 Mag. stacks
(10)2.4L 911T (72/73) $2250 Plastic stacks
9. PARTIAL MFI SYSTEMS OR PARTS PLEASE INQUIRE
10. (3)1972 911S oil console-$350, 1972 911T oil console-$275.
11. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute for Bosch 001)-pressure and flow tested-$325
12. Oil tanks(no patches). Filler tube(<1971)/dipstick/cap/sender-inquire.
(3)1972 911 $350-750(mint), (1)sporto $350.
(3)1966-1971 911 $250-550(excellent), (2)sporto $350.
13. (2)1969-1973 fog light switch $125.
14. 911 (1969-1973) mufflers-(2)FlowMaster(1/1), Bursch(2/1), Manta(2/4), $150-300.
15. Early (magnesium) and late(aluminum) 915 Transmission noses with or without speedo $150-250.
16. New clutch plate for 1972 915 (225mm) $129.
17. New reproduction aluminum license panel (1969-73) from Restoration Design $95 (free shipping). Restored OEM steel license panel $125-in red oxide primer.
18. Early 911 jacks – excellent condition – used $75-125.
19. 911S fiberglass front bumper, front and rear fiberglass RS bumpers- $250-350 each.
20. Above bumper 1969-73 fog lights-Hella TN2&4, Bosch, misc.-give your car that special look-$175-550.
21. Good starter motors 69-73 $75-125.
22. Several used working MFI electric fuel pumps-flow tested to spec. $350.
23. !978 SC ring and pinion gears-mint condition-$750.
24. Parting out 1978 915 transmission-make requests-includes clutch release parts-$TBD.
25. Rebuilt shift couplers with new bearings-$55
26. Early hydraulic tensioner kit with tensioner guards-includes oil lines, chain box covers, tensioners etc. $175.
27. Early headlight switch $75.
28. intermediate timing gear(number 1) with shaft to oil pump $150. Oil pumps-inquire.
*Included are the following: pump support bracket and AL spacer, oil breather plate with cold start thermostat, oil line to pump, fuel console with bracket and filter, 6 fuel lines, 6 fuel injectors, free moving MFI pump with good pulley, throttle stacks, bodies, crossbar, and linkages, air filter housing, air filter, and snorkel, flapper box for 72/73 air intake.
Inquire about additional parts. 20 years of early 911 collected parts mainly 1970-3.
Picture available upon request. ( X) indicates units available
email: pgeorge911@aol.com, Telephone 952 835-9969
