Results 1 to 8 of 8
Thread: quick tire question
    quick tire question
    Ive been searching without much luck, Ive got the original steelies on my 71t and the tires are really old. I just want to drive it for a while and would like a decent tire. I think the steel wheels are 5.5 all around arent they? 185/70/15 seems like an odd size at discount tire. What other options for size are out there and a tire recommendation would be great. Also, I once saw a pic of a bf goodrich tire with white lettering on a early 911. Looked pretty good What do you guys think? Thx
    1971 Porsche 911T Signal Orange/ Black
    1968 Porsche 912 light ivory/ red--original
    2006 Cayman S, black on black, Borla, PSS9's
    would 195/65/15 work?
    Search for the Vredestein Sprint Classic, it's available in 185/70/15.
    The only other options are Michelin XWX or Pirelli Cinturato. The Michelin and Pirelli tyres in that size are quite expensive at about $400 per corner.
    Vredestein is about 1/4 of that.
    Original tyre size really gives it a better stance and fills out the wheel wells. Modern tyres with narrower sidewalls just don't look right on an early 911.
    Ciao,
    n.
    EarlySRegistry #1426
    R Gruppe #525
    http://nicolashunziker.com
    Quote Originally Posted by TargaFlorio View Post
    Ciao,
    n.
    Thanks very much! Would you say 195/65/15 would not look right?
    Depends on your definition of 'right'. 195-65 would 0.2" smaller diameter. Not a huge amount but it's just not the right stance. Also your speedometer would be off (depending on how accurate your gauges are to begin with).
    Below is a comparison of the two tyre sizes. The 195-65 is a bit smaller. The 185-70 is white line around the black donut.
    I think that the early cars look better with correct tyres.
    Ciao,
    n.
    R Gruppe #525
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    and you can get a Vredestein Sprint Classic in a 165R15. Have a set on my '68...street use only, but it's been a very nice tire.
    And to my eye it looks "really right."
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Aug 2009
    Germany HG
    I've had very good experiences with the Avon CR6ZZ in 185/70-15. It has a classic design, a 'modern' rubber compound and sticks quite well.
    Best,
    Christian
    RGruppe #649
    Early911S #1788
    Forgot about the Avon CR6ZZ. I think AIM Tires in California carries them as a special order. I think in terms of price they're a bit more expensive than the Vredestein but less expensive than the Michelin or Pirelli.
    Ciao,
    n.
    R Gruppe #525
  1. Quick question on 72 T- Konis
    By Veronica87911 in forum General Info
    Last Post: 05-18-2013, 04:40 PM
  2. Quick fuchs question
    By pu911rsr in forum General Info
    Last Post: 06-18-2012, 06:02 PM
  3. Hi all........i have a quick poster question
    By Madeye in forum General Info
    Last Post: 04-01-2011, 02:53 PM
  4. Quick Cocomat question
    By obrut in forum General Info
    Last Post: 03-12-2011, 12:07 AM
