Thread: Rear radius arm removal
    Jul 2010
    Toronto
    Question Rear radius arm removal
    HELP! does anyone know any trick to removing the rear radius arm? I don't want to damage it and used up every swear word I know without success.
    Oct 2010
    Camarillo, Ca
    Heat is your friend...
    Ron
    1970 911E coupe
    1979 930 Coupe US
    1978 930 Coupe Euro
    1980 911SC sport
    1969 911S Coupe Euro
    1971 914-4 1.7
    Oct 2005
    wash dc/ los angeles ca
    If you are referring to the spring plate (mounts one end to the torsion bar the opposite the swing arm) I've actually been knee deep this past evening
    wrestling with mine as well, found a nites rest and judicious use of two pound mallet do the trick!....Bert
    Now if someone would let me know a trick to remove the original bushes...things would be peachey
    Jul 2010
    Toronto
    Thanks for the help I was going to go to the trouble to make a puller with the original cover mounting bolts. I'll give it a go. Can you still buy the rubber bushings after the heat destroys them?
    Yes, rubber bushings are available.
  1. Rear hub removal
    By Bob Harriman in forum Technical Info
    Last Post: 01-15-2014, 03:35 AM
  2. Rear quarter panel removal
    Last Post: 03-25-2009, 12:53 PM
  3. vintage roll bar main hoop radius?
    By keith in forum General Info
    Last Post: 10-02-2008, 06:13 AM
  4. help! removal of rear window Targa
    By EARLY911ZOO in forum Technical Info
    Last Post: 07-10-2008, 06:20 AM
  5. Targa Rear Window Removal
    By eaglenav1 in forum Technical Info
    Last Post: 05-30-2001, 12:24 PM
