Results 1 to 8 of 8
Thread: Repair of Red Banjo Horn??
    Aug 2006
    Chicago area
    Can you do it? My hi tone recently failed and I would like to keep the original red horns. Any help or direction would be appreciated. Thank you.
    Yes, there is voltage to the hi tone and the relay was also replaced.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    yes you can!
    hey scott, its doable.
    remove the perimeter screws and pop it open.
    check continuity across the coil, if good its fixable.
    clean out the rust and carefully sand the contacts on the "oscillator"
    (you'll know what it is when you see it, like a set of distributor points)
    reassemble with new gasket material (cut your own)
    test.
    you can adjust the tone with a set screw next to the spade contacts.
    its usually covered with a gob of black silicone.
    i've been meaning to write this up, i've got pictures.
    bob
    bob moglia
    '72 E sunroof coupe
    Aug 2006
    Chicago area
    Thanks Bob! I'll give it a go this weekend.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Aug 2006
    Chicago area
    Bob, I finally got the horn off the car and disassembled yesterday. It looks like it is dead in the water. Having an electrical industry background, I used to see returned motor starters and contactors with coils like this. Toast I am afraid. There should be a second wire coming off the coil, but I cannot find where that is or should be. Any help? Also dumb question, has anyone replaced the coil? Sure would like to fix this as it is original to the car and was working last year. Unfortunately, I think I may be SOL.
    edit: forgot pics - see next post
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Aug 2006
    Chicago area
    Sorry for the focus issue. I had the camera on auto focus and with a macro lens, it makes that difficult to do.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Atlanta, GA
    I am by no means an electrical expert, but could you take the guts out of a latter horn and install or retrofit them to your horn? I am missing one of my horns and have been looking for a replacement.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    there is no second wire, it is grounded to case.
    you can see where the wire shorted out to the case.
    replace that wire and check continuity. it might be good.
    probably more work than its worth but the coil could be rewound.
    i don't think the guts from a later horn would fit.
    bob moglia
    '72 E sunroof coupe
    Aug 2006
    Chicago area
    Bob, thank you for the reply. Yeah I was looking at this yesterday and determined that the wire shorted to the case and that caused the failure. I do know a company that manufactures coils, but I doubt they would mess with having one lonely coil rewound. Or maybe Radio Shack has something that would work. Sure would like to know the specs of that coil (wire ga, # winds, ect).
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  1. WTB: low tone banjo horn for 1972
    By jjohnston in forum For Sale: 911 Parts
    Last Post: 02-18-2013, 03:40 PM
  2. WTB: Red Banjo-style short horn
    By tomg in forum For Sale: 911 Parts
    Last Post: 01-13-2013, 04:00 PM
  3. FS: Red Banjo Horn (Tief)
    By kentf14 in forum For Sale: 911 Parts
    Last Post: 06-04-2012, 08:13 AM
  4. WTB Long Red Banjo/Trumper Horn
    By orange911 in forum For Sale: 911 Parts
    Last Post: 04-12-2012, 08:43 AM
  5. WTB: Red Horn Guts (for Banjo style)
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 03-25-2012, 10:48 AM
