Thread: Duck Tails
    Duck Tails
    I have been looking at the threads regarding early Duck Tails which seem to use either an Aluminium Frame (early) or steel frame (later) but I can't find how they were bonded together.
    I am sure someone can let me know how this was done.
    Jun 2009
    West Hills, CA
    They were fiberglassed to the frame.
    when you look at real lids they are a little long!
    That's because the fiberglass wraps around the frame.
    I've replaced sections of real duck tails and this is what I've seen.
    Espo
    75 911 SCRS
    Here's a photo of a claimed NOS replacement shell. There is no part like this in the Current PET. But maybe it was available at some point ? (i'm sure if you were connected you could get one when they were still making ducktails). It is a wide grill opening version. And as you can see it's from a later time period of manufacture, as it not laid out with the early fiberglass mat (or the normal whaletail type). Later period (like 80's - on) porsche replacement fiberglass pieces seem to be consistant with this type of mat. A place called Historika in the UK had/has this.
    Dec 2003
    West Los Angeles
    This is something you can do yourself, buying an aftermarket all-fiberglass part, removing the underside and cutting the skin off a standard engine lid. Bonding the two pieces is relatively easy, but it's common for them to separate -- even the ones commercially made separate -- at the edges. The reason you'd undertake this is to have a nice fit to the engine lid opening. Most fiberglass parts were made in molds long ago (when you could borrow a real RS ducktail as a plug). And lots of molds have shrunk over the years, so fit is iffy.
    techweenie.com
  1. Duck tails and pink pigs, oh my
    By wsk in forum General Info
    Last Post: 11-30-2011, 08:20 PM
  2. '74 duck tail WTB
    By SrfCity in forum For Sale: 911 Parts
    Last Post: 03-28-2011, 09:34 PM
  3. What is the deal with duck tails?
    By Erik@GBox in forum General Info
    Last Post: 07-01-2010, 06:46 PM
  4. Early tails, MFI, shroud, nice clock, new pressure plate, etc etc
    By Unobtanium-inc in forum For Sale: 911 Parts
    Last Post: 05-14-2009, 02:24 PM
  5. FS: Fuchs, BBS, IROC tails, seats, etc.
    By Flieger in forum For Sale: 911 Parts
    Last Post: 04-11-2009, 10:38 AM
