Results 1 to 2 of 2
Thread: 911S engine or not?
    Senior Member PeterM1965's Avatar
    Jan 2010
    Scarsdale, NY
    911S engine or not?
    Is there a way to tell without removing the engine whether or not a car has "S" heads, cams and pistons?
    I am looking at a car that has no documentation on the engine work. What I know is that the original 1968 S engine was replaced by a 1969 S engine. The engine has the correct serial number for a 69S as well as a 901/10 code. It is running on Webers rather than MFI.
    The previous owner claims that the person he bought it from told him that car was bumped up to 2.2 liters. Beyond that I have no more info.
    So my question is this: Is there any way to ascertain what is running around inside this engine without dropping it and taking off a head?
    Jul 2008
    near Ottawa, ON,canada
    there is a couple of test that will give you a good indicator but nothing 100%
    1- find a guy who has a boroscope, and look down the cylinder , and look at the recess in the piston , should be easy to tell T,E or S piston , but it does not guaranty the rest
    2-you can also measure the cam lift with the valve cover removed , with a simple caliper , each cam has a different lift# , should give you an idea , but again nothing 100% unitl you have the piece in your hand
    if it has S piston and the cam has S lift , your probability is good , if anything is off , you know the whole thing is bad
    worste case you can buy a boroscope at home depot for like 250$, and they might rent it ??
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
  1. W: '67 911S with non-matching engine (I have '67S engine #961683, Andial #140)
    By 911E4ME in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-30-2016, 05:43 AM
  2. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  3. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
  4. Wanted: 1969 911S engine or engine & 901 combo
    By Rusty Tubs in forum For Sale: 911 Parts
    Last Post: 08-17-2011, 08:56 AM
  5. Replies: 33
    Last Post: 11-02-2005, 03:13 PM
