Thread: how to separate the control arms from the cross member?
    Looking for advice how to separate the control arms from the cross member on a SWB.
    Thanks in advance
    Richard
    Atlanta, GA
    You can use a press and they will come right out. At least mine did.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Use that MAPP torch in the background to heat up the crossmember next to the bushings, they will liquefy and burn with black smoke, then put a bar in the arm and work it back and forth until they come out.
    See my threads here on changing the bushings-- you will need an air chisel to get the old ones off and a big press to put the new ones on. Not for the faint of heart (which you are not!)
    As per previous discussions on "dropping front suspension".......this would be easier if still on the car! Too late.....wedge the slot in the cross member with screw driver or chisel to loosen a bit, and drive out with a pipe to diameter or better yet, a bearing arbor.......AND a big Mexican torque wrench (hammer). Yes, torching the rubber works. But a mess.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Quote Originally Posted by merbesfield View Post
    +1
    Any advice on how to get the bushing off? One possibility is to drill the rubber, get the outer metal sleeve of and carefully grind the inner metal sleeve. Are their other ways that work well?
    Richard
  1. FS: Later A-Arms, Cross Member Assembly; $75
    By ibmiked in forum For Sale: 911 Parts
    Last Post: 01-07-2012, 01:30 PM
  2. front cross member
    By Francois Duval in forum For Sale: 911 Parts
    Last Post: 11-28-2009, 04:39 AM
  3. FS: Transmission Cross Member
    By Mudi in forum For Sale: 911 Parts
    Last Post: 09-04-2007, 07:06 PM
  4. 911 Front Control Arms AKA A-Arms For Sale
    By Bert in forum For Sale: 911 Parts
    Last Post: 08-07-2007, 04:43 PM
  5. A-Arms / Lower Control arms - are they worn out?
    By 72911E in forum Technical Info
    Last Post: 06-21-2007, 11:06 AM
