Results 1 to 2 of 2
Thread: Aligning Bumpers
    Aligning Bumpers
    Is there a trick or special procedure for aligning bumpers? I've seen so many 911s with their front or rear bumpers not horizontal with the body. My '73 has always been perfectly straight and parallel. But my new '67 is not. I've looked underneath at the rear and it does not seem obvious that they can be loosened and adjusted. Maybe shims are needed? On the front bumper, the bumper lifts up near the wheel well. On the rear bumpers, they actually bow out in the middle - maybe I need to just push it back up in the middle, with some good force.
    Any thoughts?
    Jay
    Jun 2009
    West Hills, CA
    Jay, there is no trick to aligning the bumpers properly. If the car has been bumped in the rear, the bumpers will tilt down and twist.
    The factory did use an aluminum shim on some cars on the rear bumpers.
    On the front, you can loosen the bumper inside the front compartment to level it.
    Also on the side brackets, you can put a few washers between the bracket and the bumper to level it there as well.
    This was also done at the factory on most cars.
    Espo
    75 911 SCRS
  1. FS: LWB bumpers
    By Bob Alfonso in forum For Sale: 911 Parts
    Last Post: 10-14-2013, 09:23 AM
  2. SWB Rear Bumpers
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 02-22-2012, 05:50 PM
  3. SWB rear bumpers
    By typ901 in forum For Sale: 911 Parts
    Last Post: 04-15-2008, 12:09 PM
  4. 73 Rubber Bumpers vs 72 Chrome Bumpers
    By MAPC in forum Technical Info
    Last Post: 02-09-2005, 11:05 AM
  5. Re-aligning drivers door, engine lid
    By Steve in forum Technical Info
    Last Post: 01-26-2004, 05:41 AM
