Results 1 to 8 of 8
Thread: Exhaust/Muffler straps
    Feb 2007
    Cheshire, UK
    Looking for help to understand the correct straps to be used for a 1968 (May/June '68 build) with a standard Leistritz rear box. Tried a few searches without pulling up anything definitive.
    Are the pair shown in the photo below correct?
    If correct does anyone know the specification of the threaded bolt required to fasten?
    If not correct can anyone post a picture of the correct ones I need to find?
    Thanks as always for any help.
    Tim
    Early 911S Registry #1167
    Feb 2007
    Cheshire, UK
    Anybody able to offer any advice?
    Tim
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Hi Tim
    no real help from me.............. but they look identical to the ones i have on my 73 for my stock Dansk muffler. (only had them off a couple of weeks ago to replace it) If so I think the correct bolt is a M 10x50 pan head screw according to PET
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    AS long as they wrap around the muffler, and the muffler support bracket, with about an inch gap, then they're correct. There are identical looking straps for larger mufflers, hard to tell what these are without actually trying them on. The bolts were 10 x 1.50 mm thread pitch and were allen head (same as pan head?) I don't know the length from memory, around 60 mm or so, try that and see if they will be long enough to thread. The proper orientation for the strap is the bolts should be accessed from the front lower quadrant of the muffler. The bolts are not oriented towards the license panel. This is so when removing the engine the bolts don't catch on the panel. Use anti-seize on all fasteners!
    It's 53 mm tall.
    Richard
    Feb 2007
    Cheshire, UK
    Hugh/Ed/Richard - many thanks for your input.
    Richard thanks for the pics - do you have the specific part number and more importantly can you still get them? Having tracked down an early '68 Leistritz I would really like to complete the set up correctly (I had a look on Pelican and the one they list for '65-'69 looks different).
    Thanks again.
    Tim
    You may find it easier to start with a longer bolt on each side to get things started more easily, get the straps sinched down, then install the correct type/length bolts one at a time on each side.
    John Schiavone
    Connecticut
    Dec 2008
    Woodland Hills, CA
    Quote Originally Posted by John912 View Post
    Good Tip...
  1. WTB: 2 x correct bolts for muffler/exhaust straps
    By Bantam in forum Wanted: 911 Parts
    Last Post: 06-04-2017, 07:16 AM
  2. Installation of Exhaust Straps
    By leedurrant73 in forum Technical Info
    Last Post: 01-14-2012, 01:19 AM
  3. muffler straps new
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 10-18-2011, 11:47 AM
  4. WTB used muffler straps
    Last Post: 11-22-2010, 11:29 PM
  5. Muffler Straps
    By Scott Clarke in forum For Sale: 911 Parts
    Last Post: 09-16-2010, 08:28 PM
