Thread: Mtg TTG Driving Lights ???
    Hello
    Did a search on the mounting of TTG driving lights to check on the assembly sequence. Can they be mounted without removing the front bumper? Is there access to the two bolts used to mount the bracket?
    50/50
    Apr 2004
    35,000 ft
    I did this a year ago, no, I didn't have to remove the bumper, just the grilles, of course.....the bolts go in via the backside, thru the battery boxes, the light brakcets should be threaded to receive the bolts.....typically, there are plugs in the battery boxes where the bolts go.
    Lewis
    Oct 2010
    Florida
    They should be really easy to install.
    Richard Newton
    1973 911 w/ttg lights
    Thanks Guys. Did you have to add any pieces to your wiring harness? Did you use a relay?
    50/50
    Was your car originally equipped with fog lights? They did have a separate relay from the factory, one of those round ones by the fuse box.
  1. FS: TTG Grilles for Fog Lights & Driving Lights
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 10-02-2013, 08:23 AM
  2. Replies: 12
    Last Post: 01-26-2010, 04:30 AM
  3. WTT: H1s for 118 Driving lights
    By tgittens in forum For Sale: 911 Parts
    Last Post: 06-11-2009, 12:38 PM
  4. Driving Lights
    By chicagobreezz in forum Technical Info
    Last Post: 11-07-2006, 07:57 AM
