Results 1 to 8 of 8
Thread: short stints in 911S
    Is it true that starting/driving an early 911 for just a short stint (say to move car into garage or whatever) is damaging, in particular for an S engine (I have 2.4S)?
    Apr 2010
    Kalimantan <SeaTac<Philly
    No.
    constant and frequent short drives, 20 minutes or less. and NEVER going further, gradually becomes bad for the engine oil, which leads to sludge buildup.
    if you do 3 short drives and one big long one, it will be fine. the key is that to drive long enough at some point, to get the engine oil hot enough to boil off the condensation and water that has formed when parked. the water, when not properly boiled off, becomes sludge with the oil.
    reza
    Mar 2006
    Louisville KY
    The early cars with carbs that didn't have CDI can be a pain if you don't let them run. The spark plugs on these can be easly fouled.
    Tony Proasi
    52 split window coupe
    Dec 2003
    West Los Angeles
    In general, i would rather have a 100,000 mile car that was driven mostly on longer jaunts than a 40,000 mile car that was used exclusively as a commuter. Heat cycles are a significant factor in the life of key components of these engines.
    techweenie.com
    old softie67S
    Feb 2007
    Sanibel Fl
    Short starts are terrible for exhaust systems. we have all seen condensate coming out of the exhaust shortly after start up. If the exhaust does not get hot enought to completely dry, premature rust issues.
    Tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    You can also counter the effects of moisture in the oil by changing it more frequently. Other than that, you should be fine.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    May 2006
    CT
    +1 on the moisture in the muffler issue.
    I always try to run mine on the road long enough to heat up the exhaust every time I start it.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    I've learned that once I start my car I try (my damndest) to drive it up to running temp (takes awhile) every time before letting it sit again.
    It not only gets the moisture out, but heats all the engine alloys enough to re-expand them, distributes the lubrication where it needs to go, re-'wets' the seals... and reminds 'everything' what to do and where to go.......
    We've all heard that worst thing you can do to an air cooled Porsche is let it sit for a long time......
    Well, I've experienced that this practice seems to counter most of that.... at least for about the last 125,000 miles or so....
    My .02
    Cheers
  1. WTB - Short Wheel Base 911S Soft Window Targa
    By Max (SD) in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-17-2011, 06:52 PM
  2. 901 short shifter
    By steve shea in forum Technical Info
    Last Post: 08-06-2011, 09:03 AM
  3. Replies: 16
    Last Post: 02-07-2010, 03:21 AM
  4. Replies: 9
    Last Post: 05-08-2009, 07:26 AM
  5. Short Gears
    By jaudette3 in forum Technical Info
    Last Post: 06-17-2008, 08:24 AM
