Thread: Seat belt mounting
    Dec 2006
    Bedford NY
    Seat belt mounting
    Quick question, as my car is at the shop. Does the 72 911 have threaded seatbelt mounting holes in center tunnel and sill, or are they brackets only that attach under seat. Mine are the latter, but not sure if it was original and trying to fit a set of harnesses.
    Thanks!
    Eric
    Eric W.
    72 911T euro 3.2 T-Rally tribute
    73 CS30 original survivor
    56 Healey 100M
    70 Giulia 1300Ti 2liter
    Tour Auto 04/05
    Colorado Grand 03/04/05/07/08/11/17/18
    RG # 650
    Don't believe they mounted the seat belt receivers on the tunnel until later on. And when they did, the mount is a U-bracket welded to the tunnel (you would see it if there). You can retrofit if needed by replicating the factory mount. I fabricated a mounting bracket out of a short length of trailer hitch square stock, then used a large bolt and a DOT-sized washer and lock nut through a hole drilled in the tunnel.
    The factory harness receivers attach to the mount via bolts/nuts and nylon washers as shown.
    Sherwood
    Apr 2003
    Portland, OR
    Eric:
    Until 1974, the seatbelts were mounted on the seats. The 1973 and earlier cars had the lap belts attached to the seats.
    Harry
    Member #789
    2009 MB C300
  1. Replies: 0
    Last Post: 01-06-2014, 04:29 PM
  2. FS: NOS seat belt holder for 3 point seat belt in SWB 1964 - 67
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 11-19-2013, 01:28 PM
  3. WTB Seat belt mounting tabs
    By kllr901 in forum For Sale: 911 Parts
    Last Post: 08-12-2011, 11:18 AM
  4. Seat belt mounting with RS LW seats, pictures?
    By fourteenten in forum Technical Info
    Last Post: 04-01-2011, 03:13 PM
  5. help mounting Autoflug belt retractor on rear shelf
    By 911scfanatic in forum General Info
    Last Post: 10-13-2007, 11:25 AM
