Thread: Matching oil temperature sender to gauge
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I recall reading that the oil temp sender must be matched to the gauge. Since my car is a mix of cars (although I seem to have stayed all 1969), how can I confirm which sender I need for the oil temp gauge I have installed?
    Thanks!
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Okay Keith, I'll bite, which oil temp gauge did you install? I think the standard 911 gauge reads to 300 F.The oil temp sender should have its voltage and temp range etched on the side of the hex.
    912->911 conversion
    Nov 2004
    My oil temp gauge is from a 69 (I think E) but doesn't have a numeric range on it, just the gradient scale. Not certain what that really indicates!
    Keith Adams
    Quote Originally Posted by lkadams View Post
    That must be from the standard gauge package, don't see many of those. My best guess is that it actually has the same range as the numerical but without the numbers. I'd do a bench test with a battery, hot plate, thermometer, and desired sender. Heat it up and monitor the temperature along the way, I'll bet 212 will be about halfway through the needle movement and the red band will be in the 240 range.
  1. matching of oil level gauge to sender?
    By lkadams in forum Technical Info
    Last Post: 10-29-2014, 10:44 AM
  2. FS: SWB Outside Temperature Gauge
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 03-27-2013, 02:18 PM
  3. Outside / Inside temperature gauge
    By johns4949 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-15-2012, 06:05 AM
  4. FS: VDO Outside Air Temperature Gauge
    By 67softwindow in forum For Sale: 911 Parts
    Last Post: 03-12-2009, 10:08 AM
  5. Repairing an Outside Air Temperature Gauge
    By Alan B in forum Technical Info
    Last Post: 02-24-2009, 01:05 PM
