Results 1 to 10 of 11
Thread: Wheel decoding help
    Senior Member BlackC4's Avatar
    Apr 2011
    Atlanta, GA
    Wheel decoding help
    I recently purchased a decent "lot" of Porsche parts which included several bins of parts and 7 wheels. There are two deep dish Fuchs, one deep dish cookie cutter and 4 early cookie cutters. I've noticed in several threads that there are part and date code identifiers on OEM wheels and need some help finding and deciphering them.
    One of the wheels is stamped ATS which I would assume means it's a replacement or was this the manufacturer for later wheels?
    Any help is appreciated!
    '73.5 911T Coupe Sportomatic Light Yellow (117)
    '73 911T Targa Sportomatic Light Yellow (117) - Sold
    '99 996 Carrera 4 Black - Sold
    The Other Stuff:
    '63 Corvette Split Window
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Feb 2010
    San Francisco, CA
    Pictures of the wheels including the numbers on the back sides will be helpful in figuring out what you've got.
    Cheers!
    E911SR & RGRUPPE
    '73 S Coupe #306
    Senior Member Aldo's Avatar
    Dec 2007
    Austin Texas
    Alan Domme
    Austin, TX
    '68 912 coupe
    '16 VW Golf R
    Early 911S Registry #1361
    912 Registry
    May 2005
    Oroville, CA
    Quote Originally Posted by kentf14 View Post
    Cheers!
    Part numbers are helpful, ATS was a aftermarket that became a factory supplier (common name is cookie cutters).
    H
    Apr 2011
    Atlanta, GA
    I have attached photos of the wheels. One of the wheels was worn enough that I couldn't get a clean shot of the number.
    Here is what the photos are of:
    1. black deep fuchs
    2. black deep fuchs # (couldn't find it. is this an aftermarket?)
    3. regular cookie cutter
    4. deep cookie cutter
    I didn't see any date stamps.
Size:  246.5 KBName:  fuchs2.jpg
Size:  365.0 KBName:  cookie1.jpg
Size:  264.2 KBAttachment 183466Attachment 183469Name:  greencookie.jpg
    The Other Stuff:
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Feb 2010
    San Francisco, CA
    Here's my attempt at decoding your shots.
    1. 911.361.020.41 = 7X15 original fuchs (fox head on the back) circa '77-'83
    2. can't see any of the standard stampings, looks aftermarket. I've never seen a load limit stamped on an original wheel.
    3. 911.361.023.44 = 6X15 ATS "cookie cutter"
    4. 911.361.023.54 - 7X15 ATS "cookie cutter"
    Hope this is a little helpful.
    -kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    Atlanta, GA
    Thanks Kent. Is there any way to decipher the production year of a wheel? I've seen that the purest ensure that the wheels match the year of the car. I couldn't find anything that would tell me something like this. Perhaps there is another marking on the wheel that I didn't see?
    The Other Stuff:
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Feb 2010
    San Francisco, CA
    The Fuchs will have a 3-4 digit code stamped near where the hub opening is. Your only Fuchs should be in the 77-83 range. The ATS wheels are going to fall in the post '73 range based on when they were used. I'm not sure where the date code will be on those. Sorry.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    Atlanta, GA
    I'm assuming the ATS wheels are factory installed? I can't imagine anyone wanting to make knockoffs of these wheels.
    The Other Stuff:
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Jan 2011
    DFW TX
    They have Porsche part numbers.
  1. COA Decoding help
    By Haig Haleblian in forum General Info
    Last Post: 10-13-2016, 10:38 AM
  2. MFI Number Decoding?
    By Neunelfer in forum Technical Info
    Last Post: 10-11-2011, 05:27 AM
  3. Help decoding swb tranny
    By Silverbullit in forum General Info
    Last Post: 12-04-2008, 07:44 PM
  4. Decoding the VIN
    Last Post: 11-27-2006, 06:39 AM
  5. Need Help Decoding Engine #
    By RTincher in forum Technical Info
    Last Post: 09-30-2005, 05:45 PM
