Thread: What is the correct treatment for floorboards during a restore?
    Senior Member BlackC4's Avatar
    Apr 2011
    Atlanta, GA
    Do you paint them body color, black or some other treatment?
    '73.5 911T Coupe Sportomatic Light Yellow (117)
    '73 911T Targa Sportomatic Light Yellow (117) - Sold
    '99 996 Carrera 4 Black - Sold
    The Other Stuff:
    '63 Corvette Split Window
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Jul 2008
    South Florida
    Satin black, same as dash... '68 Sporto below, must be the season for restorations.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Jan 2006
    Naperville, IL
    On LWB cars the floors should be body color with black masking the outer seat rail mounting points and the center tunnel.
    The black on the pan is actually the paint worn away and the rubber sound mat showing. The red is resale red paint. Maybe not the best picture but hopefully you get the point.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Jul 2008
    South Florida
    Good catch Andrew, I should've read his sig:'73T. ^^^BTW, pretty unpleasant color change... there should be a law.
    Russ
    ESR # 1537
    '70 914/6 GT
    Floors and Floorboards
    Quote Originally Posted by MoparBoy72 View Post
    . . . On LWB cars the floors should be body color with black masking the outer seat rail mounting points and the center tunnel . . .
    . . . The black on the pan is actually the paint worn away and the rubber sound mat showing . . .
    The photos below are of a '70 Euro.
    Black material on the floors is not so much 'paint' but some kind of semi-soft/semi-gloss kind of coating --- still soft, 'reactive.' Floor board finish is weird --- like a stain that didn't quite take. Floor mats seem to react with everything they touched --- transferring their nubby pattern to both the floors and the boards.
    Rick Kreiskott
    On a 70-73, with galvanized floor and PVC undercoating, you should not have to do anything to the floor pan, aside from cleaning up some surface rust around the pedals. Clean the underside with Simple Green, a steam cleaner, or something like that. Check that the PVC is intact. (It usually is, except in the wheel arches, where stones and mud take a toll.) Leave the top side alone. I see way too many of the floor pans on these cars get sprayed with bituminous undercoating and incorrect paint. To me, it looks cheesy.
    If you're repairing big time rust, then you'll have to get more aggressive.
    Tom F.
    Long Beach, CA
  1. CocoMat pattern for Rennline floorboards
    By Doc72 in forum Technical Info
    Last Post: 03-04-2013, 01:17 AM
  2. Floorboards
    By Mr9146 in forum General Info
    Last Post: 06-15-2007, 07:54 PM
  3. Replies: 6
    Last Post: 08-13-2006, 02:12 PM
  4. correct rocker deco treatment for late '67 911S
    By big_al in forum General Info
    Last Post: 03-01-2006, 08:35 PM
  5. Dash Treatment
    By VIper Green E in forum General Info
    Last Post: 01-13-2006, 05:17 AM
